Results 1 to 13 of 17
Thread: Duct Shapes
10-25-2010, 08:18 AM #1
New Guest
- Oct 2010
- 3
Duct Shapes
Hi
1) Why we prefer that duct shapes should be square?
2) Whats the difference between circular shaped ducts and square shaped ducts , i mean where we will prefer circular shape and where we will prefer square shape ducts?
10-25-2010, 08:38 AM #2
- Oct 2010
- SW Michigan, near Battle Creek
- 921
square shapes fit over ceilings and match up with square equipment better. they are easier to hook different sizes together. round would be more efficient in every way if it would fit.
10-25-2010, 08:54 AM #3
- Mar 2003
- 7,249
Rectangular shaped ducts have a way of being easy to layout and install as opposed to round or oval. As noted, above ceiling is a consideration on any project, especially larger commercial jobs requiring lots of airflow. Every trade knows that there will be a duct somewhere that they have to miss with their pipe, wire whatever.
In commercial real estate, area of the occupied space is treated like gold, so ceiling heights, mechanical room sizes etc all come in to play in calculations of rent, utilities etc in terms of price per square foot.
10-26-2010, 06:10 PM #4
Round duct is a pain in the butt if it gets squooshed a bit at the shop, on the truck, or hanging around the job site before it gets installed. Rectangular duct is stronger.
10-26-2010, 08:05 PM #5
I ditto everthing except
Double wall spiral duct is pretty stout also.Rectangular duct is stronger.
10-27-2010, 05:56 AM #6
I never installed double wall spiral, so I'm ignorant about it...
Round duct is also easier to take apart to clean or replace than rectangular would be, such as from an oil burner, especially for a typical home owner to do themself.
10-27-2010, 07:19 AM #7
- Jan 2006
- Virginia Beach, VA
- 12
Nice Striper Duece! Is that picture recent?
10-27-2010, 08:25 AM #8
10-27-2010, 09:34 AM #9
Square is easier to custom fab in the shop.
Rectangular is low profile
The shape matches the air handlers
Both look more expensive than round
Round provides the least friction loss
You can fit more on the truck
It's generic, and you can buy it in bulk
It's fast
It is available to any hack without a shop and therefore sometimes has a bad name.
10-27-2010, 05:09 PM #10
I strongly disagree with everything said here...lol.
IMO...
Spiral is by far easier to install than sqaure as well as having less resistance to airflow when using full radius elbows. It can also be installed at least 2x faster. And with the use of gasketed fittings, it will also seal tighter than most square duct. Our shop can whip out the spiral like you wouldn't believe. Square duct is used because of the endless possiblities of changing dimensions while maintaining a required area, especially with space limitations. Round is somewhat limited in that area.___________________________
-supertek65Chicago is an indian word for stinky!!!!!!
10-27-2010, 05:22 PM #11
10-27-2010, 05:22 PM #12
- Feb 2004
- SW Florida
- 1,243
10-27-2010, 10:44 PM #13
I agree with you on the spiral.........also have found that a round duct can waste more space than a square duct but that the square duct can carry a higher volume or the same air at a lower velocity within the same dimensions. For example a 14" diameter duct verses a 14" square duct.
