Thats quite elaborate. One thing I question is if these systems have Pressure transducers? If so make sure they are valved off. Unless there made for reading a Vac you will wreck the transducers.
I just wanted to share the typical procedure i use to pull a system down and see if you all could improve my procedure any.
1. system is usaully about 82 horsepower
2. a 26 cfm pump is used to it pull it down
3. i paint all fittings in vacuseal
4. i pull from several points in the system, ussaully an 1-5/8 line off the suction, a 7/8 line on the liguid header, two 7/8 lines off each side of the condensor, a another two 7/8 lines off each side of the heat reclaim coil
5. i use a robinar analog style micrometer (havnt found a reliable electronic one yet)the robinar is hooked up typically to the rack somewhere. I also use 2 yellow jacket electronic ones just for refrence points in reguards to looking for pockets . I put one on the oppposite side of the system at the rack and one down on the sales floor on the sys with the longest run.
6.If i have power i energize all controlls allowing valves to cycle through thier normal operations if i dont i manually run in all manual stems
7. i always start with fresh oil
8. first evacuation is taken down to 500 microns at which point i valve off all compressors isolating them from being pulled into any deeper of an evacuation
9. i pull it down twice more changing the oil inbetween each change
10. the entire process ussaully takes 4 or 5 days and i ussaully hit 50 microns or lower but it will typically climb 30 to 50 microns during a standing test on the final pull.
just curious if anyone has a more efficent way to do it
If I undeerstand you correctly, you utylize several vac pumps. Is that correct? Not just one pump operating solo?
And the connecting lines to your vac pump from the system is made of copper tubing or other such materials which will not permeate?
Do you use the tripple evacuation process to cut down on your amont of time spent running the pump(s)?
Why do you choose that level of vacuum on your system?
I assume by yoru description this is a rack system in markets?
yes there are transducers on the racks and they are valved off. I only use one pump and yes all the lines are copper that i use. yes it is a market system. the standard im required to meet is to hit 150 microns and it can not rise more then 100 points in an hour per customers specs. the idea is that there is no more then 1lb of non condensables in the entire system at least that what im told. and yes i do triple evacuate my systems.
I would imagine, with such a spread out affair of pipes and cases and all ... you would be best off using multiple vac pumps. Each located in strategic spots in the system.Originally posted by gas_n_go
[BI only use one pump. the standard im required to meet is to hit 150 microns and it can not rise more then 100 points in an hour per customers specs. the idea is that there is no more then 1lb of non condensables in the entire system at least that what im told.[/B]
Are you using this practice only on new startups? Or do you use this same method during service on existing systems?
150 microns is quite an achievement.
Tell me more.
I've never heard of vacuseal. Where do i get some? IS it necessary? And also, I use my standard hoses that came with my manifold guage set. Should I be using copper tubing? What size?
150 is a bitch to hit but its its doable. I`ve gotten it down as low as 30 microns on my best pull, and yes its for a new start up, for service i dont consider it nearly as critical to hit numbers that low considering your system is presumably dry to begin with. as far as using multiple pumps goes, you run the risk of one pump overpowering another pump, so its preferable to use one pump, the trick really is to pull from mutilple places in the system. thats why i tap it in the places that i do: high side, low side, condensor, and heat reclaim coil.
also if you try to hit numbers that low with an exsisting sytem , you`ld have to valve off your compressors or you run the risk of pulling in its seals and theres a likely chance your valves will seap through never allowing you to hit those numbers you really cant pull that deep of a vacume except on a new start up. oil in the system is another factor that will kep your micron readings up
ace i dont what kinda systems your evacuating but you should never use hoses always use copper lines. hose are desighned to hold pressure in them not keep pressure out they tend to leak in a vacume. vacuseal can be purchased at any supply house. as far as line size goes i always the largest diameter tap you got is what you use and always pulkl your vacume from at least two points on your system high and low or you wont get a good pull. and once you hit 500 microns isolate your compressor from the vacume, if you go any deeper you may pull in the ectrical seals on your motor
I was just at a training class and the instructor said that he uses nail polish (clear, not pink, we're men for goodness sake) instead of vacuseal. I haven't tried some yet, but I'm sure the nail polish is much cheaper.
Anybody swipe their wife's nail polish?
Whew! Sure glad you stated NEW start up!
Cause I was gonna say your not sober to say you can pull a vacum of even 500 microns no matter how many days you hook a pump up to the system. Not on a market. Not once it has been in operation!
Way too many valves which seep.
But I hate to go jumping to assumptions.
There was some talk about vacum on another thread and it ended with Lmtd saying that when water is being drawn out of a system using a vacum pump, it expands tremendously under 1000 microns.
Well duh. I can agree with that.
But I would never attempt to draw out a significant amount of water/ moisture/ vapor from a system that was classified as "WET".
I would first attempt to dry out that mositrue/ water/ vapor ... whatever ... before I ever connected my vacum pump(s).
AND ... I would utilise a chill chamber also
On a larger system like a market, I would primarily try to remove the non condensibles using the vacum pump. Then I would use the driers to suspend any moisture left inside the sealed system.
If I had to leave a vac pump on for very long ... that means the system is down. Bad idea.
I can change a whole lotta driers for the cost of having a system down.
And what's it take to replace a couple of 4864's? fifteen minutes?
Cheaper than evacuation. Provided you got the non condensibles out of the way FIRST!
For those here who have spent more time and energy pondering the finer points of market work. I would ask them to comment on my thoughts here.
This is not my area of greatest knowledge.
If Dave dont slap me down here ... I guess my thinking is okay.
Or ... he's asleep in the van again and hasnt loged back on yet.
Which is the same to me, as being in agreement
what is a chill chamber?
it's discussed in this thread.Originally posted by gas_n_go
http://hvac-talk.com/vbb/showthread....4&pagenumber=1
But the short story is ... it is a metal tank, real small, and it holds dry ice. The vacum pump is connected to the sealed system, in series, with this device. It is used to trap the water vapor as it heads towards the vacum pump.
It saves the pump from premature moisture saturation.
Water in with the oil in a vacum pump raises the vapor pressure at which the vacum pump can pull a system down with.
The drier the vacum pump oil, the better the vacum!
Just to add one more idea for a good vacuum. Make sure no one unplugs the pump when you go home at the end of the day to enjoy a beer or 10. It happen to us once even after we tape sign to the wall socket and tie strap the plug to the wall!
If you're worried about the power going out on you when the vacuum pump is hooked to the system in a deep vacuum, I would strongly suggest that you put a solenoid valve in the vacuum pump header to break the vacuum if there is a loss of power. The solenoid will break the vacuum and not let the pump oil and contaminates be pulled back in to the system. Also this protects the pump since it is never good to stop the pump under a deep vacuum.
Personally, I'm with R12 on the service evac. I carry three 7 cfm pumps in my truck, and if a mojor component has to be serviced, like a condenser, or a reclaim coil, etc. All three are going on there, for as long as I can stall the store managers.
I prefer to have ball valves everywhere, and I do mean everywhere, but on most older systems, you don't have that.
There is a thread on dirty oil right now, and I mentioned cleaning the separator.
The oil separator is the one component that everyone in mfg and install ignores. There should not only be lockoff valves on either side of it, but there should, IMO, be a bypass around it for cleaning it. I've installed several now, and they are the only way to go. You just need to make sure that the bypass is CLEARLY MARKED IN A HEAT RESISTANT MANNER that it is a normally closed valve, and should NEVER be left open, except during cleaning procedures. This type of thing speeds up evacuation during service.
As far as initial startup, I am more inclined to connect ten 7 cfm pumps to various points of the system, rather than one large pump.
I've seen one large pump left on lose a belt when no one was around, and then you lose your vacuum.
If you can stay and watch it, I suppose it's ok, but I wouldn't want to babysit a large rack overnight.
Every rack that I've started has been down to and held 300 microns. I think that is sufficient. I've also never watched a pump run, though. Go home, leave those ten puppies run, come back in the morning and check it. Not many contractors want to invest in a pump that large, anyway.
3 grand for 10 pumps is a lot easier to swallow than 2 grand for one...
Also, with 10 7 cfm pumps, as opposed to the OP's 1 26 cfm, I'm well over double the air removing capacity.
The only problem is the waste of vacuum oil in my method, and the time to change oil and make multiple connections.
I can't think of anyone nearby here that uses a single large pump for rack startups, though.
It's not a bad plan, though.
Of course, I jsut reread the original post, where he's saying 4-5 days to evacuate a rack. I would be strung up from the nearest crane if I ever told a job super 4-5 days to evacuate.
My process takes about 2.5 days, total, with the pumps running overnight. In MILD WEATHER. If it's real cold out, then it might take 3 days.
Dogone Dave, maybe paying attention to your words over the years is paying off.Originally posted by condenseddave
Maybe I'm catching on here ..... ya think?
By the way, that comment about 300 microns ... was that only on a start up of a brand stinking new system?
What would you pull a circuit down to if you just replaced the coil in a service meat case?
(leaking ball valves and all)
Yes. I shoot for 1000 on service, and take more if I can squeeze the time out of the nervous managers....Originally posted by R12rules
The leaking ball valves would get replaced. If they leak, they're useless.Originally posted by R12rules
Then there would be a full pulldown to 1000 or less.
Gasngo- I too used only the one belt drive pump at the rack with jumps all over the place. It's difficult to pull from other parts of the system, especially on the sales floor unless special access fittings are installed with ball valves, and most times that's not feasible. Can't pull at the cases through shraders. Often there is access at the heat reclaim coil however. It does take several days to triple evacuate a rack, changing the oil several times. After the first pull, I break with dry nitrogen. I also direct wire the pump to a breaker to avoid the unplugged situation and I have used the solenoid method also. I make up a manifold with ball valves and access fittings and will have 2 or 3 hard piped (thru ball valves again)lines from suction and discharge manifolds and more if there are split suctions. I haven't seen the 150 micros in specs, it's usually 500 to 300 and has to hold in the furthest point in the system I'm sure each chain has different specs
I always used single pumps 20 CFM or better. Three point evacuation, Suction Discharge, and Liquid. Hard piped and sweat all connections. No less than three days with nitro-breaks every morning. Pump off micron rise readings are the key, to how well your vacuum is doing.
My spin on Vac-u-seal is, does it turn into pressure-seal when you’re done. If you have a leak fix it now, then you won’t have to later.
