Results 1 to 9 of 9
    Has anyone used/own this drill bit sharpener?
    http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=8712186
    I belief HD or Lowes have them also. Your recommendation/comments on this or other brands.
    I've noticed Amazon's prices for tools are pretty good. That same Drill Doctor is almost $30 cheaper.
    http://www.amazon.com/exec/obidos/tg...hi/B0001Q2VO6/
    Colorado flatland native
    I've always been lucky enough to be able to sharpen them by eye on a bench grinder.
    Walter Matthau
    Yea ive used one, and it made the bit worse than it was when it was just dull.
    On the flute of a drill you have the cutting edge and each flute should be ground so that the cutting edge is the highest point and relieved behind the cutting edge. That thing cut the back of the flute higher than the cutting edge
    Jun 2001
    That's why we quit using it. Bits go a walkin' !!!
    Two Thumbs Down.
    Sep 2001
    East Stroudsburg, PA
    I've had one for a couple years. Tough to master. Most guys throw them in a corner after the first couple attempts, but I'm not beaten by any machine.
    Now, I use it all the time.
    You mainly need to follow the instructions, which kinda suck, to the letter, and have a pile of bad bits to f^ck around with before using it with good bits.
    I've had zero problems with it since I figured it out.
    Sep 2001
    Two Thumbs Down.
    Must be pushing the chuck too hard. Try it again with next to no inward pressure.
    Apr 2003
    Somewhere in the Caribbean
    No problems with mine, except for masonry bits. I have to go back to the instructions to properly set masonry bits in the holder every time.
    Cincinnati
    WOW!! That's exactly what my wife told me.
