Results 1 to 12 of 12
    Another Trane Model Number ??
    Anyone know what kind of unit this is and where I can locate a nomenclature breakdown?
    BWC048G300AA
    Thanks for any input!
    Jul 2010
    Andalucia
    Quote Originally Posted by Airguy01 View Post
    BWC048G300AA
    Looks like a 4 ton
    Yes- I assumed 48000 BTU. What does the BWC stand for? What I am really trying to figure out is, Heatpump or straight cool?
    Jul 2010
    Andalucia
    I tried to find something more and couldn't. Are you at the unit?
    I couldn't find anymore info either. No, all I have is the model number.
    Jul 2010
    Andalucia
    I still can't find anything from memory only I am guessing it is a 20-25 year old package heatpump. Don't quote me I will still look for you. If you are not in a hurry there are a lot of Trane guys on here. Are you a homeowner or in the business?
    MEXICO
    is a heat pump
    isn't that the over & under that sucks air thru od coil, then discharges out the sides
    Jun 2010
    U.A. (upper Alabama)
    Does it have a reversing valve?
    Nov 2007
    Hattiesburg, MS
    4 Ton Weathertron Heat Pump
    BWC048G300AA
    B: always B
    WC: Heat Pump, Packaged
    048: Cooling Capacity, MBH
    G: Design Sequence
    3: 200-230/60/3
    00: Secondary Capacity or Factory Options, 00=Stock Unit
    A: Minor Design Sequence
    A: Service Digit
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Great! Thanks for the help. It's just what I needed.
