Results 14 to 26 of 29
    Southeastern Pa
    Quote Originally Posted by newoldtech View Post
    I disagree. To me 10% means 10%.
    Especially with the capacitors we've all been dealing with lately. They don't seem to have any "tolerance" even when you use the right size one. So in a fix I might use a 12.5 instead of a 10 but I would go back to change it.
    I would also go back and change it. No reason not to.
    Actually, the tolerances have grown larger for the manufacture of overseas components for electronics. 5% isn't what it used to be. If you wanted a great deal of accuracy, you would use Mil Spec. Now, if you want any accuracy at all, you need Mil Spec.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2010
    STL
    Quote Originally Posted by timebuilder View Post
    Very true, but why even bother making the specs at all if your going to just venture out of them anyway even if just a little.
    These compenants are designed for said specs blah blah blah I do not know why people insist on pushing that bar and avoid following them to the exact. Is the risk of broken equipment really with it, maybe its job security I dont know but at times it gets aggravating.
    Oct 2010
    SW Michigan, near Battle Creek
    I think its just one of those things.
    if you had payed the big buck for the first call you would still have had the second
    maybe with the right capacitor and running part time the motor would have failed next summer instead of this.
    inside blower motors are happy running 24-7 why not outside?
    what bothers me is the possibility of an electical supply problem that is causing all this mayham
    Maybe it was the motor that caused all of the problems to begin with. And the board and cap were damaged by the motor. And the tech using a 12.5 instead of a 10, had absolutely nothing to do with the motor failing completely later.
    I'm sure the rest of you have put on a new cap that was the size listed by the motor. And less then a year later. The motor goes out. Because it was what caused the cap to go out.
    Southeastern Pa
    Quote Originally Posted by Beaver Bob View Post
    I think the answer to that is that you don't have the right cap with you, and you use the 12.5 as a temporary fix to get the customer some cooling.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Yes, of course, we've all done things totally by "the book" and still have had failures. But my point is why leave yourself open to potential problems like the OP is talking about. The last thing I want is some HO telling me that some other company said I did something wrong and caused a problem.
    I'm old School and don't do everything by "the book" but I do always try and use the right Capactior size, motor size etc. Its got to give you a better chance of success not to mention CYA.
    Southeastern Pa
    It occurs to me that the first company may have wanted to return to replace the temporary cap, but was prevented from doing so. They might have been told not to return because "this is all I want for a repair right now."
    We have to bear in mind that we were not there to hear the tone and tenor of these conversations.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    I'm not saying that that company should have used a 12.5 cap.
    Then again. We don't know that the original cap wasn't replaced a few years before this. And that tech put a 12.5 on because he didn't have a 10, and it ran for years like that. And this tech just looked at what the cap was he removed, and replaced like for like.
    Oct 2010
    STL
    Very true but its important to remember it was a temp fix and that it should be replace asap.
    Southeastern Pa
    That in itself is an excellent point.
    For that reason, I have gotten into the habit of looking at the motor label whenever I can to see what size cap is required.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2010
    Lot of interesting stuff.
    To give more info on the story to help with the question (granted I know this was my fault) and as this is all a continued learning experience for next time.
    Air upstairs went out on Tuesday night, called after hours to set up appt for next day and told tech would call me between 1-5. took half day off on Wed, no one called. called at 3:00 and lady said she remembered me calling but forgot to put me on the books. Set me up for Thursday morning so another half day off and a second day of arranging for living arrangements, etc for another day.
    Diagnosed Capacitor and Circuit board were bad in attic. Needed to service unit to look for leaks, low freon (hope I spelled that right), etc. Went outside to check on the servicing of outside unit and techs were servicing downstairs unit. told them they were servicing wrong unit and was told that he though I wanted both units serviced (didn't sit right). Told them I wanted my upstairs unit working and thats it, no need to touch downstairs. $ to replace capacitor and service unit and would be a total of $ to replace the circuit board also. the whole thing didn't sit right with me, you were already in the unit replacing capacitor, maybe another half hour to hour more to replace circuit board at $ per hour on a $ part. With everything that happened before with the appt and the service received, decided I did not want to overpay for the circuit board and would call another company out to just replace circuit board. Ran into a money crunch (health issues) and a week turned into 1 1/2 months. when fan motor went out 6 weeks later, i knew not only that I was late on getting the circuit board changed but also that we had more problems now because of everything mentioned in 1st post. that is when new tech from new company said blower motor went out because of size of capacitor and not because it was routed around circuit board. anyway, that is the story.
    not sure if the motor would have went out anyway, maybe but maybe not. should not have waited 6 weeks and lesson learned. AC company (I will not call them out) that came out first time to me were bad from scheduling to after customer service and this is a well known Texas AC Company. Had to go all the way up to main office general manager to get questions answered after 3 weeks of no return calls at from local general manager, main office manager or main general manager and after all that basically just got blown off. No big deal now.
    Thanks for everyone's help on here, this is a good site to learn.
    No prices in post, please read site rules, thank you.
    I already removed them from your post.
    Often, if there is more then 3 prices. we just delete the whole post.
    Oct 2010
    Sorry
    Understand, sorry about that.
    If you don't mind, please just remove my entire post. Without prices, doesn't really make sense.
    Sorry for the inconvience and thank you.
