Results 14 to 26 of 32
    Rochester, NY, USA
    Quote Originally Posted by dc-v tech View Post
    28A needing a 30A breaker for Condensing unit, and 2.7A needing a 15A breaker for Air Handler.
    uuuum, that would work at my Camp in the Adirondacks. It's off grid, but the generator could handle that for a few hours, to cool the place down.
    Skilled Workers are hard to find
    Thats why idiots are promoted to management
    Feb 2012
    I am looking at installing a Mitsubishi Zuba Central, living in Southwest New Brunswick. What type of heating system do you have central air or hydronic?
    Oct 2010
    The very humid south
    [QUOTE=dc-v tech;8126321] The heat pump should be able to carry 100% load without the electric backup heater ever firing.
    Did you calculate the balance point to make that determination?
    Feb 2005
    Claremont Ca
    looks ok.. would of put strut on the wall an cush clamps on lineset an would of ran emt for electrical.. maybe even clad lineset .. just my two cents..
    This is the Canadian Zuba Central Air-to-Air heat pump made by Mitsubishi Electric. Its based off the same technology as City Multi, and can heat with COPs over 1.0 at -30C (-22F). The design day for the area of the install is -18C (0F), and the unit is supposed to have a COP over 1.8 at that temp.
    This install is a small cottage, the existing heating source was electric baseboard heaters and this was a full retro with full new metal. HL calc came out at 36,000 BTU, and the 3 ton Mitsubishi unit puts out 40,000 BTU in heating. The heat pump should be able to carry 100% load without the electric backup heater ever firing.
    All the bends were done with a tubing bender, there are 3 welds on the whole system.
    So how cold will this unit actually run down to and still produce heat?
    If you can not do it right, Why even do it at all?
    anyone know if this is available in the USA or just Canada?
    Jun 2011
    Seattle WA
    Did you use the PVFY air handler with this?
    America; first we fight for our freedom,
    then we make laws to take it away.
    -Alfred E Newman
    i wish there was some more info i looked on line but it was based in Canada. Might contact local hvac wholesale shop get some info i like the looks of these units.
    In a boiler room
    Quote Originally Posted by luv2cruiserccl View Post
    I believe they are only available in Canada.
    Worry is a really gross misuse of one's imagination. -- PHM
    Jun 2011
    Seattle WA
    Check out my other thread, I'm pretty sure this is the same thing or close enough.
    http://hvac-talk.com/vbb/showthread.php?t=1026511
    -Alfred E Newman
    Sep 2011
    Augusta, ME
    Yes they are available in the USA.
    Nov 2005
    Ontario, Canada
    This is technically a 'P' Series commercial Mitsubishi condensing unit. It is rated to operate down to -40C (-40F).
    Nov 2005
    Ontario, Canada
    [QUOTE=acsolutionsllc;12435611]
    How do you mean? There is no need for a balance point calculation with a 1.8 heat pump COP vs. the 1.0 COP of electricity. 1.8>1.0.
    The heat loss matches the heat output of the unit. On a design day, the heat pump should run all day, and that is ideal. The electric heater is just a 100% capacity redundant heat source. I actually have the Em. Heat locked out through the Honeywell VisionPro thermostat to not fire unless the temperature drops below -15C (5F).
