Results 1 to 13 of 15
    Jul 2009
    Columbia, MD
    Evaporator coil leak repair
    Found a circuit flat on charge yesterday and repaired it today.
    found leak at 50psi nitrogen and bubbles to verify
    better picture of whole coil
    repaired leak with #0 tip
    also found this fitting to leak and replaced
    the coil all back together
    not a bad level for r-410a thats been open to atmosphere for who knows how long
    i also replaced the drier with a correct size one.
    Jun 2009
    Upstate SC
    Nice repair. Is that 1/2" or 3/8" going to the vacuum pump?
    Jul 2009
    Columbia, MD
    2 of the appion 1/2" hoses
    Athens, Ohio
    Nice work. It feels good after a repair like that.
    Jun 2002
    south jersey
    Boy you really took us through step by step. I felt like I was assisting you. Nice job. What do you set your regs on the oxy/acc rig fot that repair?
    Jun 2009
    Upstate SC
    Have you noticed the micron reading inaccurately that close to the pump?
    Sent from my ERIS using Tapatalk 2
    Sep 2012
    Quote Originally Posted by gravity View Post
    We actually had a rep from Emerson down to the shop not to long ago tell us that it was impossible to get all the moisture out of POE oil even with a deep vacuum. Of course he also told us that the compressors that where being install on the line should only be open to atmospere for five minutes at most. Of course this is all in side of a factory setting.
    Dec 2011
    Lower, DE
    Nice job..... looks good.
    Jul 2009
    Columbia, MD
    Quote Originally Posted by jdblack View Post
    it will show lower then what the system is actually at. after it has been running for a while i will close the core tool that has the micron gauge on it. then im readings furthest from the pump.
    Jul 2009
    Columbia, MD
    Quote Originally Posted by jnsrose View Post
    it depends on the tip.
    i used like 5 act and 10oxy with the 0 tip
    and then when i use my #15 rosebud i will use about 8-10act and 10-12oxy
    the tip is important for the repair. if i used my rosebud on the coil i would have burnt everything
    Sep 2012
    Seen this in action. Most of the pipers where I work love their rosebuds. Find a leak in a unit during test, they will burn the hell out of everything around it while fixing it. Really POs everyone down the line. I normally get stuck fixing pipe insulation. I have been trying to fix the leaks myself but I don't have the skills of people doing that type of work 24/7 for years.
    Nov 2011
    GA
    Good job man, ive got a few trane package units around here that ive had do do the same thing, one in the same spot
    LIFE IS TOUGH, IT'S EVEN TOUGHER IF YOUR STUPID!
    Sep 2012
    NW Louisiana
    Quote Originally Posted by Elfshadow View Post
    The EMERSON rep was 100% right. It is impossible to remove moisture from POE oil. I know, we have tried in the lab. The oil must be changed. The minimal open time is 100% correct too. POE will wick moisture from the air at an alarming rate. It is extremely hydroscopic (sp). This is why the compressors are shipped with plugs and about 5 psi of dry air.
    Knew it was a Trane, red compressor!
    CT
