Results 1 to 7 of 7
12-09-2004, 11:20 AM #1
- Jun 2001
- Indiana
- 19
Which is preferred, Belt-Driven or Direct Drive? Why?
Thanks so much for your input!
Thank you for your time! ~KMT
12-09-2004, 03:50 PM #2
Member - bad email, contact Admin
- Sep 2002
- 1,389
krtpworks
IF you can hit the static pressure fairly close and get the required air you are looking to attain, direct drive is much better. Really quite simple reasons:
No belt to replace, No bearings to grease and eventually replace, since the blower longevity increases due to lower service requirements the blower will remain in service longer, and the blower operation sound levels are much lower since there is no drive noises or vibration. This could become critical depending on the application the exhauster is used for.
If though, you need to adjust blower speed to attain a desired air flow then a pulley must be adjusted hence a belt drive is required.
Hope this helps.
tom
12-09-2004, 03:53 PM #3
- Dec 2004
- 41
we normally try to specify belt drive,just for balance purpose. And for long run, if you have to add some air on this fan, you have better chance to keep the existing fan, just use a longer motor.
12-09-2004, 04:17 PM #4
- Sep 2002
- 1,389
ceng
Sorry, I thought you asked why a direct drive might be better than a belt drive. Sounds like you already had your answer before you asked the question. In your case it would appear you need belt drive and the maintainence schedule that goes with it since you have another post here about laboratories.
tom
12-09-2004, 04:50 PM #5
Belt maintenace ..... one of my pet peeves.
If the manufacturers would get off of a few more pennies ... maintenace can be lowered drasticly. If there is space, going to 2 belts or going up one size (A to B, B to C) dramaticaly reduces maintenance and increases the life of the belts and pulleys.
If you have full service contracts that include free belt maintenace .... do this upgrade as each pulley wears out and never worry about them again between annual inspections
In my opinion, most belts and pulleys are marginally sized ... making mucho moola for us
Sam
Know-it-all? Nope, not even half!
12-09-2004, 04:52 PM #6
- Dec 2004
- 41
twc pipe, what I post here is not related with my first post.
12-13-2004, 08:16 PM #7
- Jun 2001
- Indiana
- 19
Thank you!
To the three people who answered me (twcpipes, ceng, and boat racer): All excellent answers! Thank you so much for your input on my belt-drive vs. direct drive fan question. Your input is very much appreciated and will certainly contribute to wiser fan selections in my future.
