Results 14 to 26 of 177
Thread: Testo 550 Reliability?
10-20-2010, 06:10 PM #14
I noticed that the new ones came with the ground clamp.
I'm glad to hear your success with them.
It's too easy to hear the negative comments and too hard to get people to post the good ones.Every problem gives us the opportunity to choose from several solutions: stupidity, ignorance, indifference, or brilliance. Which one will you choose?
10-20-2010, 07:15 PM #15
10-20-2010, 07:45 PM #16
- Sep 2002
- 717
10-20-2010, 09:29 PM #17
10-20-2010, 09:45 PM #18
I have used my testos all late spring and summer and now into fall of this year and I have had NO issuses with mine,, like the showing of superheat and subcooling at same time and the blacklighted screen is good.. like the heatpump option for not having to swicth your hoses around-- maybe I got lucky or whatever but I have had No issuses... I would recommend them
10-20-2010, 11:23 PM #19
My 1250 is mounted on a two valve and if I'm evacuating I'll use two core removers with the DC hooked to the high low sides and refer tank and then two 3/8 hoses direct to my pump off the thru ports of the core removers. Be willing to bet it's quicker evacuating than just about any 4 valve out there.
If You Can Dodge A Wrench You Can Dodge A Ball
10-21-2010, 01:46 PM #20
11-19-2010, 08:00 PM #21
- Jan 2005
- Massachusetts
- 250
I used to squeak my way by with 22 but with all these new units I had to order one. Ask me to install a steam boiler any day over an AC call.
11-19-2010, 09:54 PM #22
I have had no problems with mine either. If you want to spend 3 times as much you sure can do it. Personally I don't think it's necessary.
I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
Veto Pro Pak - The best tool bag you'll ever own
11-30-2010, 07:33 PM #23
New Guest
- Jul 2010
- Alabama
- 2
We bought 3 Testo 550's back in Sept and love them. I took the supplied grounding clamp and put a ring terminal on one end and slid it between the rubber housing and the manifold. A drop of super glue on the rubber side with a wire tie around the middle nipple and it stays put. I use the clamp whenever I am running refrigerant through the hoses as the manual dictates. I would like to find a stainless braided charging hose that would solve the grounding issue without having the extra wire but haven't had any luck so far in finding one.
So far the Testo has made service calls a lot quicker and we have had no problems with them..
11-30-2010, 07:42 PM #24
No return.
- Jul 2006
- NW burbs of Detroit
- 6,058
01-08-2011, 09:15 AM #25
- Jul 2009
- Plant City, Florida
- 2,198
I just bought one and it comes with a grounding wire and a warning that it needs to be used because of the blended refrigerants like 410a and them being charged in the liquid state.
I like it so far and in some ways like it better than my Digicool 1250 and it is a much better value, I had to replace the sensors already on my digicool and they were $125, yet they come with the Test 550.
01-08-2011, 09:17 AM #26
- Jul 2009
- 2,198
