    Oct 2010
    Waco Texas
    Question 410a leak detector
    We had this argument at the shop before about using leak detector rated for r22 for r410a it shouldn't work but Im always over ruled. I say it shouldn't different oils but u guys give me your opinion. Also one for 134a i think would work on 410a. I would rather buy one to be sure than miss the leak
    Why would oil type matter when looking for refrigerant leaks?
    Now, a GOOD leak detector will detect CFCs, HCFCs, and HFCs with no problem.
    I have used the H-10 detector on all 3 types for many years with good success and I recommend it unconditionally.
    Now, I have recently had some very positive experiences with the D-tek select that are starting to sway my opinion. Up until a few months ago, I would have told you that the Select was the biggest piece of crap that has ever been marketed as a leak detector, and I haven't been shy about saying so.
    Somebody read some of those posts here (thanks, BTW) and helped me to get an updated and upgraded Select.
    I must say that I am quite impressed with this detector and would recommend it as well.
    Oct 2010
    Waco Texas
    Didn't the older detectors look for chlorine and 410a doesn't have any thats my point I should asked about I dont know why i even put anything about oils
    Lancaster PA
    You are correct.
    Talking Leak Detectors
    I use the Bacharach Informant-2. It's a great detector, very reliable. Although I use it for R-134 and combustible gases (gasoline) it will detect most refrigerants. It may be useful to check for furnace leaks, possibly a few pro's might know. For my needs, it the best of both worlds. ibis1
    VA
    I use the Tek-mate as a beat up detector, it detects 410, though it seems not as well as 22. If I don't find it with a quick scan I pull out the Bacharach H-10, that will usually find the leak, but if the leaks too small, it may take some time.
