Results 1 to 13 of 18
    best ultrasonic leak detector?
    I want to buy an ultrasonic leak detector to add to my arsenal. I want to know which one you guys think is the best and why. Thanks
    Jun 2010
    Freehold, N.J.
    Ultrasonic leak detector
    We use a Amprobe brand ultrasonic leak detector. I don't know the model # but it's nothing too fancy. It comes with the detector, 2 probe attachments, headphones & carrying case. Runs on standard disposable batteries.
    I've had very good success with this technique in finding the tiniest leaks.
    I believe the unit runs about $250 & definitly worth it.
    Jun 2009
    StL, MO
    My experience with the AccuTrac VPE has been disappointing at best.
    UA LU 562
    las vegas
    i have an old uld 1 amprobe that still works well ..
    i alsohave an accutrak that after a small learning curve works very well.
    on some leaks i have better sucess pulling the unit into a vac. to
    leak check rather than using a pressurized system. must have something
    to do with the sound frequency they work on.
    South Carolina
    I use the Amprobe ULD, a CPS 790, an old halide torch, a stethoscope, nitrogen & bubbles and my ears.
    Of the bunch, the Amprobe and the CPS are my favorites.
    “Two things are infinite: the universe and human stupidity; and I’m not sure about the universe.” —Albert Einstein
    Oct 2007
    ATLANTA
    Quote Originally Posted by marvin View Post
    Do you mean using the ultra sonics while the system is in a vacuum?
    las vegas
    Quote Originally Posted by AtoZhvac View Post
    go to the accu trak web site & you will see that they can be used to locate a vac. leak.
    had my first experiance using one on an old trane sidewinder & we
    were able to locate the leak in a vac. with it. dont know what brand it
    was but remember it was made in england.
    have found the accutrak vpe to be very reliable but i usually start with around 50 psi & work my way up as needed. has something to do with the frequency range they operate in.
    St. Augustine, Florida
    Old timer at previous job only used ultrasonic. His success rate was very good. I just ordered an Amprobe to add to my 3 h10s (1-"A", 1-"PM", and 1"G") I use the "G" most, but sometimes grab my dtek, though it is the most frusterating of all, really succeptable to wind through returns/airhandlers etc. Hope the ultrasonic rounds out my leak checks........
    Sep 2006
    Florida
    Damn. They don't even list the price, must cost a month's salary.
    South Carolina
    When I bought mine, ten years ago at Grainger in Charlotte, NC., I paid about $445 and that included the transmitter.
    South Bend, In.
    Yikes, its gotta be good even the navy requires it on their subs. Which means big $$$$$$.
    So you didn't ask, what you though was a stupid question. Now how, are you going to tell the boss about your stupid screw up?
    Nov 2008
    Meriden, Kansas
    I agree about the frequency. We use accutracs, never tried an amprobe. They seem to always find the leak we don't find with a D-tek or bubbles. But they miss some of the leaks that we find easy the other ways. I think it has to do with frequency.
    I always start with a D-Tek select and then try something else if that doesn't work. Lots of times the D-Tek goes off in an area but I cant pinpoint it, then I pinpoint it with the ultrasonic or bubbles.
    Anything I say here is only my opinion. Even if you understood what I said.... What I said may not even be what I meant.
