    Question
    I need to know how many amps (max) an old furnace blower might pull.
    I kept the blower from my 25 yr old carrier updraft gas furnace and now want to use it in my shop as an exhaust fan.
    I want to order a 2 pole 4-way switch to control it, but have no clue - (and no way to measure) how many amps it draws at startup.
    Wudn't be all that bad if nobody knows - then i could go buy that amp clamp i always wanted for my Fluke!
    SE Michigan
    Cant you just look at the rating label on the motor that you kept?
    Now the freaks are on television, the freaks are in the movies. And its no longer the sideshow, its the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and were dealing only with the freaks. - Jonathan Winters
    blower specs II
    the housing ust has a clean spot where a label used to be - i stuk an inspection mirror inside the squirrel cage and didn't see anything on the motor itself
    SE Michigan
    What was the model of the furnace?
    furnace model
    we will never know - i replaced it with a high efficency unit about 5 years ago - well - maybethere is a way - i could poll the neighbors and see if any of them still have the orig unit - i hope not - i think it must have been about 50% efficient - our subdivision was built btwn 76-78 -
    the answer is....
    9.6 amps
