10-08-2010, 09:30 AM #1
New Guest
- Oct 2010
- 1
How to calculate cost for a gal of chilled water
Does anyone know how to calculate the cost for a gal of chilled water?
10-08-2010, 11:39 AM #2
- May 2008
- Central Pennsylvania
- 415
Well I'm thinkin' that would depend on what chiller you're using??? Different machines will have a different kw per ton rating. If you knew the kw per ton and the size of the chiller, you should be able to do a bunch of reverse math and get a guesstimit of the cost per gallon.
10-08-2010, 06:47 PM #3
- Mar 2003
- 7,253
actually, you need to figure all power including pumps and cooling tower, then do the math. lets say a total central plant might be 1.3 kw/ton these days, and you are using 2.2 gpm/ton. you can now get to the math. unless you really want a good number, then you need to figure costs for winter work, repairs, and depreciation, as well as operations.
10-11-2010, 03:46 PM #4
- May 2008
- 415
10-11-2010, 05:00 PM #5
You may want to look into this:
http://www1.eere.energy.gov/industry...iller_tool.pdf
