Results 1 to 13 of 14
    Jan 2010
    Israel
    Carrier 19XR Liquid Carry Over
    Centrifugal compressor Carrier 19XR we found liquid carry over in the suction elbow. We first tried to remove R134, about 100 kg.
    We checked for excessive oil in the refrigerant. We checked the float valve we still have carry over and maybe, there is a problem with the distributer line in the bottom of the evaporator.
    Any suggestions to assist us to resolve this problem would be welcome.
    Jun 2010
    U.A. (upper Alabama)
    Quote Originally Posted by mot View Post
    Where was ref. checked for oil? If on bottom evap. remember oil is going to be on the top of the refrigerant.
    MEXICO
    works properly, the oil return system, which operates the machine conditions?
    Feb 2007
    Baltimore MD ( Balimer, Murilyn)
    You said you had "liquid carryover in the suction ell". Was the carryover causing problems? Amp fluctuation? What was the superheat reading?
    The oil return system pulls oil from the bottom of the ell and returns it to the sump.
    Not in Iran
    perk., u said oil is on top of ref?? i thought oil is on bottom of barroll
    Jan 2005
    This type of thing kills me. Very few seem to know some basic principles.
    Oil floats on water, right? Check out specific gravity of refrigerants in comparison to water. Then figure out where the oil will be.
    Simple.
    These damed things will slug liquid with a gallon of oil in evap.
    Make sure the charge is correct and then go from there.
    Let us know if you are unable to figure out how to determine if the charge is correct.
    Not in Iran
    Quote Originally Posted by Carrene #2 View Post
    Simple.
    ok ., then y on an rthc do they have a gas pump that takes oil from the bottom of evap and put back to sump due to oil migration??
    Western Wa
    Carrier skims oil from the top of the refrigerant level, and York Yts suck it off the lower part.
    Anybody else ever scratch their head at that one?
    God Bless the USA
    Oct 2006
    Central Texas
    Quote Originally Posted by mlkwal1 View Post
    An RTHC is not a flooded barrel, it's a falling film. The refrigerant is metered in through the EXV @ the top, and sprayed over the tubes causing the liquid refrig. to FALL down over the tubes it will pool up at the BOTTOM of the barrel, keeping in mind the EXV is controlled by the liquid level sensor, it's not a deep level. The oil will fall down to the bottom, and is picked up by the gas pump.
    The Carrier has a flooded barrel, where refrigerant is FLOODING the barrel keeping the tube submerged. Refrigerant is fed from the bottom of the evap. the oil is going pool up on the top. As mentioned before the Carrier XL/XR are SENSITIVE for oil log which will cause carry-over, something fierce.
    Sic Semper Tyrannis.
    Jun 2009
    Florida
    Quote Originally Posted by servicetrane View Post
    Ummm...What?
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    8th grade
    yeah
    rthd is also falling film 2 eexv's
    if you run cold condenser water even for a short tim
    you will be pumping refrigerant back up from the bottom of the evaporator!!!!!!!!!!!!
    using your shiny little g5 twin
    I WILL SELL WORK,GENERATE BUSINESS, GO GET NEW CUSTOMERS!
    YOU SHUT THE HELL UP AND QUIT RUNNING YOUR MOUTH!
    Not in Iran
    Quote Originally Posted by Randy S. View Post
    an rthd is a screw machine, where the carrier we are all talking about is a centrifugal same as york yt., is this the reason y oil is at top and not bottom due to the diff in styles? and when u say lower part of the york , r u talking about the bottom of the barroll of the york. also what exactly happens when u get liquid cary over in a centrifugal? eat up bearings?
    8th grade
    alot of questions in one post
    as you know the rthd is a falling film machine
    the liquid comes in the top of the evap through two eexv's and the refrigerant falls to the bottom
    there are two solenoid valves that return oil.
    I am told they also have this on the new wheels so it does not matter that it is a screw or a wheel!
    just about any other machine the oil that is not mixed in with the refrigerant
    MISABILITY of the oils differ. will be on top. most all of the big chillers we have worked on in the past were flooded barrells!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    a float that controlled the liquid level.
    so when you said earlier you thought the oil would be on top you would be correct.
    like mentioned earlier carrier skims oil off the top.
    as far as carry over, is what dx guys call liquid slugging.
    I have seen some pretty good damage done to the wheel!
