Results 1 to 7 of 7
Thread: Research topic ideas
09-30-2010, 10:46 AM #1
New Guest
- Mar 2010
- 3
I am currently going for my two year degree in HVAC technology and in my technical report writing class we have to do a research project that deals with our major. I'm having a tough time coming up with what to do my topic on. I have to choose a topic from one of the options listed below. If anyone has any topics they feel would be good please let me know. Any suggestions would be greatly appreciated. Thanks.
Ø Research two or more products to determine which is (are) superior.
Ø Research different test procedures to find which method(s) is (are) most accurate.
Ø Research different software for the same application; determine which is preferable for the application.
Ø Research/identify new materials presently used for a product or for prototypes. Tell why the new materials are better than those previously used.
Ø Research/identify new labor-saving devices, tools, or instruments. Compare them to traditional or historical devices, tools, or instruments, and tell why the new ones are preferable.
Ø Research new environmentally friendly products, devices, procedures, or services, and tell why they are preferable to those currently or traditionally used for the same purpose(s).
09-30-2010, 10:59 AM #2
I saw a short segment on TV last night about a company in Maine that is reportedly producing a heat pump that will work in below zero temperatures. The name on the units was Acadia.
Using marijuana instead of other drugs because it is not as addictive is like shooting yourself in the foot with a 9mm instead of a .45 because the bullets are smaller.
09-30-2010, 03:00 PM #3
I, don't know why you are here in ARP asking a question about work.
That being said, research air filters for one subject. They are in plentiful supply at Walmart, you can start from the cheapest, 99 cent each to the costliest filters that go for around 15 dollars.
Then do some research on insulation for duct work. Its changed recently from R6 to R8. you could specify why.
09-30-2010, 03:06 PM #4
Moved from ARP to GD
09-30-2010, 05:42 PM #5
09-30-2010, 07:32 PM #6
- Mar 2003
- 7,249
how about traditional cast iron boilers with on/off burners verses modulating condensing boilers with modulating burners that match the heat loss of the structure and run at higher net efficiences.
10-01-2010, 04:36 PM #7
New Guest
- Mar 2010
- 3
Thanks for the responses guys. You have been a big help
