Results 1 to 13 of 24
    hvtec is offline Regular Member - bad email address Contact Admin
    Jun 2001
    Question
    Is there anyway to install some type of time delay alarm on a walkin freezer that would remind personnal that the door is open? The facility I work at has a commercial size kitchen/dinning bldg, and staff are constantly leaving door open after accessing product. Maybe a strobe light as well. Any suggestions??? confronting kitchen supervisor does not work.
    Thanks for your help.
    You could install a door closer or curtain. Kitchen people do not understand the concept of closing the door!
    Dec 2000
    oklahoma
    Confused
    I have had the same problem.I have hung plastic curtains,talked with supervisors and workers,had fits of rage and nothing helps except curtains alittle. They will close reach-ins but anything they can walkin to freezer or cooler they will leave door open. Sorry I can't help but your not the only one who has this problem.
    Orange County CA
    You could install a door switch circuit , that feeds through a time delay (maybe 5 minutes), that circuit would/should activate either a ambulance siren or a train air horn and strobe light.
    send checks to: nedflanders27@hotmail.com
    Annapolis, MD: ragboat capitol of the world
    Yeah, plastic curtains help, until they tie them to the side because they are in the way, duh
    Sam
    Know-it-all? Nope, not even half!
    walla walla
    add a microswitch with arm on door of freezer hooked up to a light so everyone can see light is on
    Lancaster PA
    Hook up a door switch to a delay, and sound a buzzer, that anoys them.
    People will ignore a light when they are busy.
    Be glad you got a job.
    Dont try and teach an old dog, new tricks!
    It's not your problem to fit it. It is only your responsibility to fix the freezer when IT breaks.
    If you can have a door closure installed ... so be it. Have that taken care of.
    But as far as creating attention to the door beling left open and setting off alarms ..... you only draw attention to yourself.
    The issue here is you have people problems. You already know that!
    And this is something outside of your job description!
    You certainly dont want to come across as the grouch!
    I feel your pain. BT/DT....
    Jul 2001
    Gold Coast of Connecticut
    How about installing a new self closing door and frame thats what i would do!
    Sep 2001
    East Stroudsburg, PA
    Modularm makes such an alarm.
    http://www.modularm.com/door.html
    Anchorage Alaska
    Some good freezer door companies have adjustable spring loaded doors. Where I work (in the Arcitc) all outside doors on all buildings are freezer doors. Its -40 up here alot of the time so freezer doors keep the warm in insted of out. Anyway they all have wind up adustable springs to assist in closing against the wind and folks too busy to shut the door....
    John
    Orange County CA
    John
    WOW that's very interesting!! I never thought about that .
    That would be something to see....do the doors have heaters in the frames too?...( totally serious question )
    Anchorage Alaska
    Yes - lots of them do have heaters - this place started pumping oil in 1976 and lots of these doors are origional so you can be sure that all the heaters dont work. Im brand new on here so I will try to figure out how to send a pic...
    John
