Results 1 to 7 of 7
    RTAC155 oil filter & Check valve replacement
    I will be replacing the oil filter on a RTAC155 soon. I spoke with Trane tech. support, and they stated that there was a service bulletin released on replacing the check valve behind the oil filter. Tech support suggested that the check valve be replace at the time of the oil filter replacement. So, I was wondering if anyone knew of any tricks that might be hepful, or snags to look out for.
    Thanks.
    Jun 2010
    U.A. (upper Alabama)
    Be sure to evacuate filter housing along with compressor, or you will get an oil bath.
    cperk is right. You'll still have like 100-150 psi in that filter housing after a service pumpdown.
    Good thing you can't remove the last bolt before removing the drain plug.
    I don't know of any bulletins that relate specifically to the oil control valve. There is a very general procedure outlined in one of the troubleshooting manuals, though.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Jun 2009
    Florida
    Quote Originally Posted by Jojo98 View Post
    Thanks.
    That would be RTAC-SVD02A-EN
    Oops...it's a shame your email addy isn't in your profile.
    Good luck...and bring lots of rags.
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    Jun 2010
    A 2" socket for valve also.
    Not in Iran
    Hmm dave anderson
    Quote Originally Posted by ChillerWisperer View Post
    How do u know dave?
    Jun 2009
    Florida
    Quote Originally Posted by mlkwal1 View Post
    How do u know dave?
    Been through a couple of his courses.
