    May 2008
    Central Pennsylvania
    RTAA clear language display
    Hi all. I have a clear language display to replace in an RTAA over the weekend. Looks like it should be plug and play, just wanted to make sure there arn't any other tricks I need to know about.
    Thanks.
    chiller plant
    It,s not a plug and play
    write all your settings in service set-up and machine configuration menu before. look rtaa-iom-4a page 67 -75 password and menu
    A land down under
    Good tip to record all the settings but they should be safe when changing over the CLD. The chiller settings are stored in the non-volatile memory of the chiller module - the CLD only provides for the man machine interface (MMI)
    Jun 2010
    U.A. (upper Alabama)
    Quote Originally Posted by Screwit View Post
    Right on bro.
    May 2008
    Thanks for the replies fella's.
    Jan 2010
    In a Pineapple Under the Sea
    I have replaced the CLD's on cvh's without even shutting the chiller down first and it never missed a beat. Then again I did not have line voltage in the control panel either so it will be a different story on an rtaa.
