+ Reply to Thread
Results 1 to 15 of 15
Thread: HVAC pipe leaking
    Sep 2010
    HVAC pipe leaking
    Hello:
    One of the exhausts pipes of the HVAC system in my garage appears to be leaking. There is a PVC pipe that comes out of the HVAC and is not connected to anything. It was just left as if it was a drain out pipe. Everyone once in a while it sort of drips water. Normally I figured it was due to condensation. A couple of days ago I noticed that there was a whole trail of water coming out of the pipe to the entrance of the garage (the HVAC sits at the very back of the garage). When I checked it, it had continuous water dripping from it. I put a bucket under it and kept an eye on it. The same day I had to empty the bucket twice (2 gallon bucket). Yesterday and today, there is just a bit of water at the bottom of the bucket so not much water coming out of the pipe. My neighbor had mentioned that he though the pipe was an auxiliary to the main pipe in the HVAC and that it should only drip water if there is something wrong on the main pipe (ie. clugged up). My questions are:
    1. Is this pipe that is sticking really a 'backup' PVC pipe that should not really not be dripping regularly?
    2. The HVAC system is about 6 years old, is this 'clugging' a common problem? what can cause it and how can I prevent it?
    3. How serious can this be? and how much could it cost me?
    4. is there anything I need to be aware of when the HVAC guys comes out to take a look at it so that they don't pull a fast one on me?
    Thanks,
    Sep 2010
    Dubuque, IA
    pictures are worth a thousand words. And quick advice on this forum.
    Jan 2006
    In a land far, far away
    It sounds like the axillary drain. It's job is to swing into action when the primary drain fails.
    More than likely, your main drain system is just clogged. After 6 years, your unit is probably very dirty and in need of some regular maintenance. Have your HVAC guy come out and give it a thorough cleaning and service. Price discussion is not allowed, but this probably won't be too costly.
    Definitely don't let it go this way. You could cause rust or mold in your HVAC unit, and even damage to your home. Get a pro out to get the unit back shipshape.
    hard to see what you're seeing; from here
    Nov 2001
    east kansas
    Quote Originally Posted by GarageGuy69 View Post
    Hello:
    4. is there anything I need to be aware of when the HVAC guys comes out to take a look at it so that they don't pull a fast one on me?Thanks,
    Sorry we can't answer your question. We would be putting a damper on the fast one that we pull on people.
    Beware of advice given by some guy on the Internet.
    Apr 2005
    Antioch, IL
    Wink
    Quote Originally Posted by Milk man View Post
    Too funny!
    Nov 2009
    Saskatchewan
    What kind of fast ones do you guys pull as a rule?
    I use the old *do my best and pretend it was my home I was working in*
    Sep 2010
    k_fridge:
    Thank-you for your reply.
    I will get some pictures today just to make sure I expalined it properly.
    Everyone else:
    I certainly didn't mean to degrade your profession or to insinuate that all HVAC folks are dishonest, however there are dishonest people out there regardless of what they do for a job and I wanted to make sure that I had some guidance as to what the issue may be and what will need to get done to fix it.
    I'll get a shot of the unit which should make it easier to figure out.
    Thanks!
    May 2010
    Oxford, UK
    GarageGuy69,
    I'd like to ask your advice as a customer, what sort of tricks do you guys like to pull on tradesmen? What should ring an alarm bell? How do i avoid being shafted?
    With your problem i would say its likley to get more expensive to fix the longer you leave it.
    Cheers,
    Monkey
    I hate when axillary drain pans swing. they always seem to splash water everywhere then. LOL...
    Jan 2006
    I think I've been watching too many Chuck Norris movies.
    Beautiful, Philadelphia, the City of Brotherly Love!
    The trick with pulling a fast one is that if you pull it fast enough the customer doesn't see it and thinks you are an honest contactor. So the moral of this story is always pull your fast ones fast, because pulling them slow is dishonest.
    Sep 2010
    This is the image of the pipe that I was talking about. Notice how it just seems to stick out of the HVAC unit. It didn't use to drip but it is now. I put a bucket under it so that the water it wouldn't run all over the garage, I have to empty it about once a day now.
    Is it an auxiliary pipe then? how serious could it be?
  14. #14
    Aug 2010
    Seattle Wa.
    Yeah you're main drain port is probably clogged up. Call a company to come out and clean the coil and pan.
  15. #15
    Sep 2010
    Thank-you.
    That was exactly the problem. I had someone com out and fix it.
    The guy was actually very helpful and truly professional.
    thanks again.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
