Results 1 to 13 of 20
Thread: superheat
    Sep 2010
    huntsville al
    superheat
    is it worth finding super heat or subcooling if the units are mismatched
    In the work truck
    Why would you not calculate superheat and subcooling on every system?
    Sorry not allowed to give DIY here. Call a pro.
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    Sep 2010
    huntsville al
    iam an tech and i have other service tech saying with mismatched units it is not that accurate
    In the work truck
    Quote Originally Posted by kenlafountain View Post
    Dude I'm sorry but I dont understand the question here.. Why would you not?
    Are you in this trade or what?
    May 2010
    Oxford, UK
    Mismatched systems will find a balance point somewhere, its up to you as a tech to make it the best balance point for the systems life and customers pocket.
    Sep 2010
    huntsville al
    i use a fieldpiece guilde on each call i was at the supply house and two old times said that with mismatched airhandler and cond it was not worth the effort i take care of about 600 apts and all most all units over the years are mismatched. this does not make sense to me but with only 10 years exp i was just asking
    Sep 2010
    huntsville al
    thank you that's what i have been doing
    Feb 2007
    Corpus Christi, TX
    superheat and subcooling should be done on every system.
    2 pressures, 4 temperatures = success
    especially on a mismatched system you could cause damage of the proper sh/sc isnt achieved.
    Testing....Signature on Full Site Forum
    Aug 2010
    Owensboro, Kentucky
    TC said it best "2 pressures, 4 temperatures = success". These are manufacture system set point to ensure system efficiency. If you charge units accordingly then you have returned the unit back to factory specs. If your still having trouble understanding just email me and I will be glad to go in greater depths, I think all techs, rookies and veterans should go back to the basics as most of the time the problems we encounter are simple, we just tend to forget the basics. Thank You
    Mar 2009
    Being the system is mismatched it might be harder to determine the ideal superheat and subcooling, but you still need to look at these values. Remember the compressor is a vapor pump. You can not compress liquid so you better have SH. If you have a TX valve it will automatically adjust to maintain a certain SH, so you have to check charge by subcooling.
    yeah!
    thats alot of effort!!!!!!!!!!!!!!!!!
    man i am tired just thinking of all the effortit takes to measure superheat!
    true knowledge exists in knowing that you know nothing.
    Generally, people that say its not worth the effort.
    Don't know what the readings are telling them in the first place.
    what if your wife says to you?
    NO! it is not worth the effort!
