Results 1 to 13 of 14
    Sep 2010
    Question Fumes coming from basement
    What can cause fumes to come from basement even if the heat is not running. It slowly leaks upstairs and seems to be worse when we are gone and come back home. The basement has the furnace, but the heat is not running, but the air is running. We know we have a mold problem and that is evident from the musty smell. But the other smell is like fumes. It doesn't appear to be coming from the furnace...It is a rental home. But we cannot tell what that exhaust fume odor is. It is worse in basement. It has been this way since we moved in 5 months ago. I am home most of the day and I don't want to get sick from this.We have no garage and have oil heat and central air. It is an older home built in 70 and has some electrical problems I think. The lights blink a lot. It is a rental home and we are moving in 3 weeks, but I am kind of scared to even stay the 3 weeks.. I am home most of the day and my husband is at work most of the time. I have been kind of sick and not sure if it is related to the house. It could be the allergies in a new location.
    Langley, BC, Canada
    Fumes could be a gas leak from the furnace or hot water tank....if your smelling it upstairs then you could have a big leak. It could be off gases from the hot water tank. Radon is colorless and odour less. Does it have a particular smell? if you feel sick and light headed I wouldnt be inside, I would be opening up all the windows as well. Call your landlord and get him to call the utility company or a heating outfit to come and look. This is something that should be addressed right away without delay.
    *Proud Member of UA LOCAL 516*
    Jan 2010
    Athens GA
    It could be 100 differant things,most of them not good for you.
    One thing that comes to mind is the chimney is plugged and you still have a water heater.
    Call your landlord and tell him you are afraid to sleep in this place and to get a service guy out there right away.If you have to tell him you will not pay any more rent until you know its safe.You could get a CO detector right away,Sometimes they are free from the fire dept,or the town code enforcement office.
    Even if you opened all the windows and doors ,don't sleep where there might be CO in the place.
    PS the lightsd blinking a lot means there will be a fire,and it will probably start inside a wall somewhere.
    From what you have written I believe you are in actual danger living there.Take that for whats its worth.
    Sep 2010
    Wa.
    Get out, call the utillity company where you are, also have a Heating Service Technician there 10 minutes ago.
    The midwest.
    Sometimes the plumbing P-traps will dry out and you'll get an oder.
    But with the lights blinking and you're feeling sick, I would be very careful.
    Get the landlord to check everything out today.
    Good luck, let us know what they find.
    Fort Worth, TX
    I know you said you have oil heat, but do you have a natural gas burning water heater (I know, I know...why would there be oil heat and natural gas water heater in the same basement...just have to ask to cover the bases).
    What do these fumes smell like?
    Is it worse when the furnace runs? The same? Better?
    When you run the central air, does the smell get worse, stay the same, or get better?
    Is the odor strongest in the basement? I know you said "worse", but is it THE WORST in the basement vs. higher in the house?
    If you fear for your safety and health remaining in that house, I would leave ASAP.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Cincinnati, Oh
    BEFORE you call a heating and air company to inspect things: Call your landlord first. You unfortunetly don't have the right to have it repaired/inspected without his/her permission first, and you could be the one who ends up footing the bill.
    Call the Landlord right away. Suggest to your landlord you should get a HVAC professional out. Maybe the utility company. Most likely HVAC. Around here the utility company ain't worth a crap.
    "Just get it done son."
    Dad adjusted
    Quote Originally Posted by shophound View Post
    LOL... Strange as it may sound. that isn't all that uncommon around here.
    In the city, you find a good number of places with an oil hot air furnace, and a gas fired water heater.
    butler pa
    a call to the local fire dept may be wise...here they have co detectors and
    will test for it if you think you have a co issue...
    Fox Lake IL
    hope she has done somthing befor it is to late.... call your fire department
    Jun 2010
    Philadelphia PA
    Sounds like the basement is pulling a negative pressure and the flue is blocked!
    A call to the Landlord is first and if someone doesn't show up then call someone and deduct it form the rent.
    Fort Worth, TX
    Thanks for that...since I live in slab foundation/no oil heat country, I felt...
    ...when I said that.
    Massachusetts
    Obviously we can't actually smell what you're smelling and so it should be checked by a knowledgable technician on scene. Oil units can create a smell as the moisture from condensation in the basement mixes with residue from last winters heating. Any spilled oil or fuel oil stains can also create odors. However, you need to have someone live, in the basement, determine the source and the solution. We can't do that from here.
