Results 1 to 9 of 9
    Western New York
    W/I freezer condensate trap
    So where do you place your condensate drain trap on a WI freezer, where the drain goes outdoors in the Northern states, where we have freezing temps in the winter.
    Normally, I run a 7/8” copper line, straight out (with a good pitch and a union) and the trap runs parallel to the outside wall. Everything covered with 1/2'” armaflex and a self-regulating heat-tape. I run a 1 ¼ PVC sleeve thru the wall so I can get the heat tape outside for the trap.
    I have seen traps inside the freezer, and they seem to work OK as well. However, you have to heat the trap year-round this way. On the up-side, the trap can't be vandalized if it's in the box.
    So what do you do? Ice, you can’t answer… you have been out of the NE too long!
    Experience is what you have an hour after you need it.
    Nov 2008
    Hudson Valley, NY
    Cool
    I like the way you do it with the 1 1/4 PVC IF YOU NEED TO YOU COULD PUT A TEMP CONTROL for your trap for cold weather
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by baub View Post
    ...Ice, you can’t answer… you have been out of the NE too long!
    White Lake, MI
    Where is this outside line draining?
    Western New York
    That would mean two heat tapes and a T'stat.- I like to run one from the coil to the outside.
    Pavement, grass, hog pen? It's country here! I have a couple of places that let the condensate drip into a pan for the chickens.
    Ice- it's time to get the snowblower out from the back of the pole barn and service it. Miss the good times?
    Jul 2000
    Guayaquil, EC
    One day I'll tell you about an incident I had with a snowblower many years ago.
    I'm glad I don't need to deal with the need for them any more.
    Now I just watch out for the Gators.
    Southold, NY
    Quote Originally Posted by icemeister View Post
    I’ll take the Snow Blowers
    Thank You
    Sep 2010
    I have done some before with no trap but used a kazoo tube on the end of drain that they use in transport trucks. That is what a truck box company calls them but there may be anther name then kazoo tube
    Jan 2006
    Near Atlanta, GA.
    I never put a trap inside the box, always outside. But, I'm in the south.
    I've seen hundreds without traps and no problems. I know what the book says, but....
