Results 1 to 7 of 7
    Sep 2010
    Confused Rudd Furnance transformer/fan relay wiring
    I just bought an old house that has an old Rudd furnance with a Rheem 47-19807-01 transformer and fan relay.
    The previous owner changed the wiring so that the fan runs all the time.
    I would like to change the wiring back so that the fan runs only when the furnance or air condition units are running.
    Does anyone have any recommendations on how I should do this.
    Any advice will be appreciated.
    Dec 2006
    Middle Tennessee
    never the less, if you have not burned it up yet and let him do it!
    Jan 2010
    Athens GA
    DIY and letting the smoke out of an electrical device go hand in hand.
    I suggest that you call a contractor for a clean and check on your equipment and he can changethe wiring while he is there,its a very simple proceedure that only takes a few minutes.
    Previous owner may not have wired it to do that. Could be a defective/bad part. Call a contractor and have the system checked.
    Sep 2010
    Confused
    Thanks for all of the advice.
    I am fairly certain that it is not a malfunction.
    The yellow wire from the fan relay is connected directly to the hot wire coming from the electrical panel.
    When I disconnect the yellow wire from the hot wire where should it be connected.
    The relay has two black wires on one side of the relay connected to the transformer.
    A red, black and yellow wire on the other side of the relay.
    The red wire goes to the limit switch and the black wire goes to the fan motor.
    So would it seem logical that I could connect the yellow wire to the black wire going to the fan without burning up the relay?
    Thanks again.
    Sorry. This is NOT a DIY site.
    Call a contractor.
    Jun 2007
    Round Rock
    I would call somebody out. You can do more damage and cost yourself more $$$ if you let the pro's take care of it. The dude could be fibbing to you. Why would you hot wire a motor to run all the time when all you have to do is turn the thermostat fan setting to "on"? Sounds like something fishy is going on.
    I like DIY'ers. They pay better to fix.
