Results 1 to 13 of 17
08-30-2010, 12:19 PM #1
New Guest
- Aug 2010
- 4
Replacement system sizing? Load Calc vers Quotes.
Home built: 2000
Size: 2064, measures 1842
Construction: Wood frame, brick, full slab
Insulation: R38 Celling, R13 walls
Celling: 10"
Windows: 26, single pane (384 sq ft total)
Current HVAC: 4 Ton, SEER 10 Amana
Issue: High electric bill (500 June/July/Aug), lack of proper cooling (can't get the house below 78)
I have had three in-home quotes for a new system. All three have quoted the same size system based on installed equipment. None of them did any kind of load calculations. Sears collected some of the data, but the rep's computer was in the shop.
So after reading this forum, I saw the need to do the load calc myself. Much to my surprise, the load calc results came is far lower then expected. With single pane glass windows, it came in at 2 tons. With double pane glass windows it came in with 1.5 tons. So how can the installed system be so over size?
I would really like to get the right kind of system installed, and finding someone that will do it right seams to be hard here in Houston. Any comments on where I can find someone here in Houston would be great. Or anything else I can do to insure i get the proper system.
08-30-2010, 12:23 PM #2
Give me a call number is in my profile.
08-30-2010, 12:37 PM #3
It is not uncommon to find over sized equipment installed and even less uncommon to find a hack who will accept any size that's on the existing system. Finding a company that will do a proper load analysis is a must. The test is to ask them over the telephone how they size the equipment. Don't invite any company that doesn't clearly state that they're doing it room-by-room Manual 'J' load analysis in for a quote, as you're wasting your time. As you already suspect, they're gambling with your money! They might be cheaper on the install in initiallly but might also be lots more money in operating expense and hugely more expensive when it comes to lack of comfort. So shop carefully.
08-30-2010, 12:41 PM #4“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
08-30-2010, 12:54 PM #5
New Guest
- Aug 2010
- 4
08-30-2010, 12:56 PM #6
You're welcome. I know it will help if you use it.
08-30-2010, 01:07 PM #7This is the correct deal, no better and probably not any worse than any place else.Mr Bill
Houston does not have any patent on finding folks to do a job right, trust me, there all over this Country and other Countries.
IMO they only way to decide on a company to do any major work either at your house or business is to talk to several. 3 seems to be a good place to start. If you are still not satisfied do a couple more.
There are a bunch of really good contractors out there. Also some who are looking to separate silly folks from there $$$$.Good Things Come To Those Who Wait, But Only the Things Left Over By Those Who Hustle.
Abraham Lincoln
08-30-2010, 01:20 PM #8
- Jun 2009
- Albuquerque NM
- 2,443
Most contractors will oversize if given the chance. It's safer for them because it avoids even the slightest possibility of having enough capacity. Most homeowners don't even know that a system can be oversized. When I tell my neighbors their systems are oversized I get a quizical look from them. When I try to explain it, I usually get a blank stare and sometimes their eyes glaze over.
08-30-2010, 01:23 PM #9
Call Al, there's one who knows what he's doing with Houston humidity! Glad he's offered to help. Always nice when a HT member is nearby.
08-30-2010, 01:25 PM #10
New Guest
- Aug 2010
- 4
08-30-2010, 01:31 PM #11
Your right! Houston seems to be the "Bermuda Triangle"of heat and humidity, it takes a lot of years of experience, living and working here to get a system right. If you think you can just perform a load calc. here, and run with it, your mistaken, you better also have lots of experience and some common sense here, or you will get yourself into some deep, deep do do.
08-30-2010, 01:35 PM #12If YOU want change, YOU have to first change.
08-30-2010, 01:44 PM #13“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
