    Charleston,SC
    Exhaust fans and speed controls
    This might have been asked in controls but, here goes...Have older roof exhaust fans that seem to be causing negative pressure in several kitchens. Might be asking the age old question...speed control of psc motors. Basic 115 vac psc motors (with 3L belts) and have heard that introducing a "speed controller" will cause over heating and thermal ov/ld to open. Have looked into the new vari-green motor from Greenheck and this seems pretty cool. Any ideas besides the expensive JCI S66 or nimbus? Anybody installed the vari-green yet?
    Apr 2010
    West Virginia
    most likely the make up air is the source of the negative pressure, dirty blower wheel, or loose belts.
    Jim
    Jul 2010
    Fishersville Va
    "older" places might not even have makup air.
    Can't pull out what you don't have.
    It's all a balancing act betwen the proper air flow out, the proper air flow in, while keeping the A/C affected as little as possible.
    St Paul, minnesota
    Quote Originally Posted by stryder View Post
    if belt drive then change sheaves and install a VP sheave on the motor
