Results 1 to 10 of 10
    Jul 2010
    CHICAGO
    how to size a return vent for a room
    I was called to a job where the customer did some remodeling to
    a store, the customer turned it into a dance studio. she added a reception
    area that measures 12x2 x 19x8 and the height of the place is 8x9.
    When I looked at the vent setup in the reception area had 2 supplies
    and no returns. I informed them that they needed a return in order to
    circulate the air in the reception area. I put in a return, I used 8' round flex
    duct and added a perforated lay in on the ceiling. But the air is still not
    circulating. My question is should I have used rect.ductwork instead of
    round, is my return to small for the space.? I know how to check cfm
    for residential but not sure on commercial units. I brought an
    aneomometer but the instructions on it are not clear and I do not
    know how the unit works I called the company that makes it and they
    told me to go to the place where I purchased it for instructions.
    This is my second job were the issue is are flow and it has me
    confused.
    Dec 2003
    Middle of Florida
    What is your Static pressure drop across the coil?
    Or you can hold a thumb up to the vent if it covers the vent you are OK , if it does not you need to make it bigger!!!!!!!
    If common sense is so common how come so few of us have it!
    Jul 2010
    CHICAGO
    secorp,
    I do not understand about the thumb part what do you mean?
    chicago suburbs
    everything in commercial is 14" round.
    FILL OUT YOUR PROFILE!!
    Jul 2010
    CHICAGO
    Thanks for the advise Tinner 73
    Jun 2010
    St. Louis
    Also buy and learn how to use a duct calculator, these handy little things can be very useful. Of course its no good if the unit itself was sized improperly for the building or room it is heating/cooling
    Jan 2010
    Quote Originally Posted by tinner73 View Post
    Jersey
    that is very funny, Everything is 14", I guess all the work I did with 6"-20" is all incorrect. Well thats the rule of THUMB i guess
    Life is too short to give a SH*T about the small things, Thing could always be worst!
    Karma is great!
    Aug 2010
    Swamp land
    I don’t want to say to much. That way I will not get beaten up that much. The BTUH load for each room should calculate duct size.
    Dec 2003
    Middle of Florida
    Talking
    Quote Originally Posted by GITMO64 View Post
    secorp,
    Stand back 20 feet a see if your thumb covers the vent, or break down and purchase cardboard cut outs of thumbs on E bay and use them. every five feet you back away equals 5 tons.
    I hope you realize I am kidding......
