    Mar 2013
    swan valley idaho
    bj valve for wolf
    i need to replace a bj oven tstat on an old wolf oven. can't find any model serial info.
    oven is single door black with raised red wolf head emblem on oven door, range top above. standing tcouple pilot.
    i usually order through herritage, but they will want model number i'm sure. any ideas?
    Jun 2013
    South East US
    You can order a universal BJ kit from most suppliers. It will have a multi-tap outlet bell, that can be (carefully! Read the included instructions) rotated to accomodate any orientation, and will come with a knob/dial etc for oven use. You may need to cut off the supply line flare if it uses that style, and install a compression fitting to adapt it to the universal BJ, which has NPT pipe threads in the bell. I'm not near my catalogs at the moment or I'd give you a part number.
    Mar 2013
    swan valley idaho
    ok i think i saw that kit on line at a couple places. I think oven may be c or ch series from pics i found on line. ill try ordering this morning
