Results 1 to 13 of 13
    Apr 2002
    Lucas, Texas
    Lennox Heat Pump 1987 model
    Model # HP18-511V-4P
    Serial # 5187E38429
    Thanks! Jerry
    3.5 ton
    Apr 2002
    Lucas, Texas
    Thanks HeatpumpMan!
    The 511 is 4 ton unit. If it was 3.5 ton it would be 461
    RSES Certificate Member
    RSES-SWRA President
    Sorry to bring up old post
    Is 311U a 2 ton and 411U a 3 ton? Just curious.....thanks
    Look at the nearest 1/2 ton and round up.
    30,000 round up to 311 for 2.5 ton
    36,000 round up to 411 for 3 ton
    Of course without knowing exact evap match and looking at the ratings, could be a several thousand BTU range on any size.
    burlington county n.j.
    hp18-511 cheap builder grade 4 ton
    Jul 2002
    Zelienople, Pa
    Size and efficiency of
    M# HS29-261-2P
    S# 5896H23023
    Thanks!
    10 seer 2 ton
    Lennox HP
    Try 1-800-453-6669.
    Nov 2001
    2 Ton -- 261 -- 024
    2 1/2 Ton -- 311 -- 030
    3 Ton -- 411 -- 036
    3 1/2 Ton -- 461 -- 042
    4 Ton -- 511 --048
    5 Ton -- 651 -- 060
    Which have you done ?
    Apr 2001
    west virginia
    i was always told the first 2 number equal btu IE 261 is 26,00o btu . 311 31000 and so on its easier to remeber for me anyway
    toolpusher has them right
