    york fan blowing direction
    I am a newbie and not an expert
    My two story home has (2500sq.ft) two ac units
    The smaller unit is tripping the breaker
    Wired breaker to an unused(same rating) one still trips
    measured capacitor,it is okay .5ufd, 45ufd(two in one)
    To isolate the problem further. Is it ok to power the fan compessor seperatley?
    How long I can run cpompessor witout the fan on top of it?
    I took apart the fan(incudig blades, rotor) and put it back together.No the the way air blowing out in ths unit and the bigger unit is different.In the bogger unit air is bowing stright out (90deg vertical) through the grill. In the smaller unit(i just put it back together) air is is coming out like in a 30deg angle area through the grill. Don't feel a lot of air movemnent in the 90deg area.Did I do anything wrong?or this is normal?
    Yours comments appreciated
    Lancaster PA
    Site Rules, Sorry, this is not a DIY site.
    Aug 2010
    Charlotte, NC
    Jacob, You might consider joining the < We don't promote DIY sites, or any competing forums >
    As far as the moderators deleting prices it would be well for everybody here to remember the problem we have in the housing industry right now is a new home will appraise for less than it cost to build it. We are all a part of this problem and companies in the business of installing HVAC in new construction are contributing to the problem too and will have to sharpen their pencils too if they want to continue to eat and keep trucks on the road.
    Last edited by beenthere; 08-20-2010 at 04:14 PM. Reason: Removed name of DIY forum
