Results 1 to 13 of 23
Thread: Turbo Air BGF-23
08-19-2010, 04:12 AM #1
Turbo Air BGF-23
Just got new account with a ton of these **** boxes on the list for the this week. First call is no lights... replaced the door bulb with a new lamp and no light. Are these door lights thermostatically controlled? Nothing in the scematic shows this... just a lamp switch. getting voltage with a voltage stick but not sure what voltage or which pins to measure for readings. Lamp holders look good. Unable to locate parts and TA is no help. Had to acctually call TA for part #'s then (that took 2 days) then he gives me a # to a illinois distributor. Call him for truck stock 3 days ago and havn't heard back. Anyone have a source for TA parts? Thinking this box may have some type of t stat that only makes on lower temps to warn that temp is rising. Looks like I,m in for a long ride with these TA freezers. Anyone work with these boxes alot? I need a crash coarse on the nuances of these boxes. Thanks
The Difference between Genuis and Stupidity is Genuis has it's limitations.
Chicago Furnace Repair
08-19-2010, 03:43 PM #2
I HATE TURBO AIR
I called T.A. tech support over a month ago, they still have not called me back
Just download whatever you can get from their website and read it. You might find this useful. Have fun.
08-19-2010, 08:01 PM #3
08-19-2010, 08:27 PM #4
Banned
- Apr 2010
- West Virginia
- 636
08-19-2010, 08:29 PM #5
Banned
- Apr 2010
- West Virginia
- 636
08-19-2010, 08:39 PM #6
08-19-2010, 09:08 PM #7
08-19-2010, 09:09 PM #8
Banned
- Apr 2010
- West Virginia
- 636
08-19-2010, 11:07 PM #9
This is exactly what I need Thanks. I will also incorporate ohming the wire back to the pins to eliminate the posibility of any breaks. If I can confirm that The wiring is good them I just need to confirm if the ballast is good which is where I have trouble determining. I will read over the material. It seems that every time I had a bad ballast it was open with no voltage on the output but I guess it is possible to get one that is weak and not putting enough voltage out to heat/light the bulb.
08-19-2010, 11:20 PM #10
- Jan 2010
- 4,410
How many lamps ?
08-19-2010, 11:22 PM #11
One sign and one door lamp inside the box.
08-19-2010, 11:31 PM #12
- Jan 2010
- 4,410
So two lamp ballast ? Old style ballast was 2 reds 2 blues 2 yellow . Reds & blues out & yellow for the jumpers. Ballast would typically be marked with a open circuit voltage which you would test between the red & blue leads and compare. Now the last one i changed was new style and you could not follow color code but by following the wiring diagram you can make the necessary changes.
08-20-2010, 08:42 AM #13
Professional Member*
- Mar 2001
- 1,407
They are tough to deal with @ TA. I've done three warranty calls for them since 2007. They call me, send a work order, bug the heck out of you until you get there, call the job, and talk to the owner-manager while you are there to make sure you have shown up, and then won't answer the phone, or call back when you try to contact Tech Support, or the warranty rep. Send all parts without question, and pretty much rely on you to make their systems run. Tried to purchase some out of warranty parts from them, and even tho I have done work for them in the past, if I need to purchase parts, I have to go thru a distributor. I use Case parts. After the last chinese (pun intended) fire drill with a freezer I repaired under warranty, I'm considering a divorce.
One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
