Results 1 to 13 of 19
    Nov 2007
    Whittier, CA
    anyone ever design a heater for a dog house?
    Trying to figure out a good way of providing heat to a large type insulated doghouse....found the following via google
    http://cozywinters.com/shop/dog-house-heater-ac.html
    i'd like to be able to control the temp. with a thermostat and would probably put the rubber flaps, kinda like they use for walk-in boxes at the door....
    N.E. Iowa
    That dog's name better be "Lucky"!
    ______________________________________________
    Sign petition to limit Congressional and Senatorial terms. http://www.termlimits.org/
    "We may have all come on different ships, but we're in the same boat now."--Martin Luther King Jr.
    Grottoes VA
    Jun 2010
    Hendersonville,NC
    I know this sounds weird. Around here most people put flaps over the door and have an electrician wire a light socket in there and use a 100 watt bulb for heat.
    Cal
    Keep the dog comfortable and looking good for the ladys.
    I don't know
    All that's necessary is a 1500 Watt space heater and a long extension cord - resistance heat is expensive so borrow some electricity from the neighbors, exterior outlets permitting.
    Is this thread for real?
    Jun 2009
    Bakersfield, Ca
    Did somebody say," hot dog house"?? 'Cause that sounds grrrreat!
    Nov 2007
    Whittier, CA
    HAHAHA....let me explain a little more.
    It's for a couple of sea otters in which they built a little doggy house basically out of plywood and insulated. The problem is that if the air temp is too low (below 80 at night) they won't mate, which apparently is a problem.
    I originally told the keeper, "duh...just throw in a heat lamp".....well I guess they think it may somehow burn itself on the metal screen on the cieling of the box. I guess they tried the heat mats and the otters would leave, weren't happy.
    So yeah this whole thing is pretty silly.....
    Ohio
    Feed the otters some Viagra and Budweiser........
    Problem solved......
    I need a new signature.....
    May 2010
    east brookfield ma
    why not use a small electric water heater and pump warm water under the floor like raidiant water heat?
    Dec 2009
    maroon lazyboy
    Don't kill your doggie!!!
    We found a customer who heated HIS dog house with the little 2" pvc pipe that blows out nice warm air from the furnace!!! Don't know how often he had to replace the dog???
    Nov 2007
    Whittier, CA
    Quote Originally Posted by evankoehn View Post
    hahaha
    Nov 2007
    Whittier, CA
    Quote Originally Posted by darryl123 View Post
    Animal keepers tried heating the floor already and they are convinced that the animals don't like it......
