Results 1 to 13 of 17
    villalba,p,r
    hi guys; I have scotsman model BH360S ice mach the problem is every 5 or 6 day do ice in all evaporator, I check the solenoid and I thing is ok by continuity.the unit has only one year.and I check the plastic damper too. any other idea. THANK
    villalba,p,r
    freezing up and no drop the ice, Iam not check the water filter,that is possible the filter cause ice. thank
    dude-try a good cleaning,may help
    villalba,p,r
    thank guys I dont see the filter back when look at it gave me account thankvery much
    what initiates harvest on these,cant remember (suction thermistor)??
    Probably water related problem.
    It fills once and stops. Once water is gone, ice machine harvests.
    If your not getting ENOUGH water at the first, then your in trouble.
    I got a book on them if this doesnt work.
    And DIceMan probably has this model memorized anyway. He jus LOOOOOOVES dem Snotsmanz!!!
    villalba,p,r
    hi; ok I push off bottom for 6 second and supose to do the process first all the green lightbulbs on ok no problem, but goes off again. if I push freezin bottom goes on but still freezin and then goes off. any idea THANK
    My books are too new to cover even listing your model number.
    Next time I'm in Austin, I'll pick up a book on your series. Contact Scotsman. They have excellant tech support.
    cleaning?
    isn't that the first thing a tech would do before he came home at night and racked his brains while eating over this problem!?
    ya know.. when things get like this.. don't feel ashamed to call the MFG. (or ever for that fact!!)
    there is usually a guy, that answers all the questions in under
    20 " billable " minutes... sometimes it gets down to " what serial #, as the problem existed from serial...... to serial..."
    Keep ALL the guys #s handy...
    Don't ever be told or FEEL, like you should know or remember it all.
    You'll do O.K.....
    maybe a diagnostic prob with the board? but let them tell ya..
    good luck.
    dan
    Dan, you da man!
    That was a good word.
