Results 1 to 8 of 8
    Looking for service manual for HEIL/Tempstar furnace M/N NUGM100EHA1 S/N L952933209
    I know it's 100 BTU and that it's from 1995
    I'm looking for the specs and service pdf plus any service bulletin.
    My concern is the heat exchanger issues plus I want additional info.
    NEEDED ASAP!
    Connecticut
    First off you could start by posting in the right section...DOLP!
    Aug 2010
    Karachi, Pakistabn
    Confused
    what xactly do you need ??
    Sorry if I posted this in the wrong spot.
    I just want the installers manual with the specs and schematic.
    Oh I almost forgot if there is a service bulletin indicating any issues- like with heat exchanger issues or anything really.
    Aug 2010
    Karachi, Pakistabn
    Confused
    installer manual for which equipment & brand ???
    A customer has a HEIL model number NUGM100EHA1 Serial L952933209
    I believe Tempstar is the same company.
    Anyhow the nameplate read HEIL and I have tried their site no luck.
    Dec 2010
    pittsburgh/butler
    Your'e equipment is sold by Sid Harvey Co try contacting them. As the local dist.
    Bye
    Artie
    Apr 2010
    CANTON OHIO
    need sev. mans.
    Quote Originally Posted by alfa-75-man View Post
    they are the same try to contac. the list i give you by fone . morrow controll canton ohio. ask for keven at the counter. robertsons in canton ohio. last choise bonsky sheet meateal brad sharp on hiil and temp theyb are simple. if the heat ex is bad scrap it cheaper and easer to replace it. the only trouable i had with them were ing system and the honey well valve in the late 90s their was a recall melfuction .bonsky is located in green town ohio 330 area code. if you think the h ex is bad did you smoke test it.
