Results 1 to 10 of 10
08-13-2010, 03:20 PM #1
- Aug 2010
- 23
How to connect threaded 3/4 pvc adapter to drip pan under A-coil
I am adding a 3/4" pvc drip drain from the A-coil drip pan.. I am using a 3/4" adapter (male threaded) into the drip pan (I am guessing as it appears I have to unscrew an existing plug to add the new line.
I am certain to no use pvc cement for the connection to the drip pan...what am I supposed to use?
Here is a pic for reference...I am adding another drainage line to the right side...it appears they used silicone caulk on the left side...is this acceptable?
08-13-2010, 03:23 PM #2
08-13-2010, 04:05 PM #3
- Jan 2007
- N.E. Ok.
- 1,300
My best advice, Don't use a tool to tighten.
08-13-2010, 04:15 PM #4
- Aug 2010
- 23
08-13-2010, 04:31 PM #5
- Oct 2009
- Phoenix
- 155
teflon tape... pipe dope... more silly-cone...
08-13-2010, 04:35 PM #6
- Sep 2009
- Covington, KY
- 159
you will do fine with teflon tape, easy to put on and not messy
08-13-2010, 04:44 PM #7
- Aug 2010
- 23
08-13-2010, 07:39 PM #8
Why isn't your HVAC contractor doing this?
08-13-2010, 07:52 PM #9
What is wrong with the existing drain. One 3/4 PVC drain will usually keep up.
08-13-2010, 08:07 PM #10
- Aug 2010
- 23
Everyone thanks for the responses.
Why isn't your HVAC contractor doing this?This should answer your questions...What is wrong with the existing drain. One 3/4 PVC drain will usually keep up.
http://hvac-talk.com/vbb/showthread.php?t=611632
