    Jun 2007
    What do you guys use to cut the fins away?
    gonna try and fix my first leak in a outdoor unit its leaking right on the top pipe going into the outdoor coil, so I only need to splice in about 3 or 4 inches of copper but wondering what to cut the fins back with maybe a metal blade by hand? I was a service tech for about 12yrs but i never had to fix a leak in a outdoor coil I went into the sales side of this buisness for prob this reason lol.
    Houston,Tx.
    I just pull them out/away with my needle nose.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Oct 2009
    WI
    Pliers.
    Jun 2007
    That easy ok I was just worried about the fins on the bottom side of this loop were it goes down to the next loop.
    Oct 2006
    The Beach
    Mr. Bill is right. With a good pair of needle nose pliers you can remove just the about of fins that you need to. Keep that heat real low. That copper could be real thin.
    Blue Fox
