    Aug 2010
    Toronto, Canada
    Upgrade Choice: 2-stage AC or 3-stage Furnace?
    I'm about to replace our aging furnace and air conditioner with new units from Carrier. I have had multiple quotes from qualified vendors and have settled on the Infinity 96 2-stage furnace (58MVB) and a 2-Ton single stage Performance 15 air conditioner (24APA5). I'll be installing the Infinity control with a Carrier humidifier and HRV added in as well.
    Here's my question - For slightly more $ I can either:
    1) Upgrade the choice of furnace to the 3-Stage Infinity ICS (58MVC) paired with the single stage AC
    2) Upgrade the choice of AC to a 2-Stage Performance 17 (24APA7) paired with the 2 stage furnace
    I live in a 1300 square foot backsplit home located in the Toronto, Ontario area (built in mid 1960s), and our cooling season is comparatively less than the heating season. For this reason I'm inclined to upgrade the furnace over the AC. Also, our existing single stage 2 ton AC has served us well with reasonable humidity control.
    I'm wondering what the community has to say? I'm basing my decision more on comfort than efficiency. Would a 2-stage furnace + 2 stage AC provide better comfort than a 3-stage furnace + 1 stage AC in my situation? Is the 2-stage AC overkill for my climate and size of home?
    Thanks!
    Massachusetts
    I'd upgrade the furnace without a doubt. In addition, you might want to investigate the costs of substituting a heat pump for the AC unit and have a dual fuel system that might also deliver greater comfort during the shoulder seasons (temps above 35F) as well as some improved economy over using the gas furnace all the time. Alternatively, if humidity is a concern in the summer, you could have a whole house dehumidifier incorporated into the duct system rather than a 2-stage AC system.
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by HHM View Post
    I'm
    Thanks!
    I choose the 3 stage furnace/13 SEER single speed a/c. In your climate will need supplemental dehumidification to maintain <50%RH during the wet cool times of the warm season. On a hot day my a/c removes 6 gals of water per day, while basement dehu removes 2-3 gals/day. On wet cooler days the a/c removes 1-2 gals and the dehu removes 4-5 gals per day. I maintain <50%RH through my 2,100+1,700 sqft. structure. If I had a 2 stage a/c, I would still need the dehumidification maybe not so much? Use the money saved on the 1 verse 2 stage a/c on a good dehu like a Santa Fe Compact.
    Regards TB
    I'd choose neither of those upgrades. I don't see much improvement in comfort from either one, especially given they cost more. If you wanted to spend some money and get a better value, I think the heat pump is a great idea. You'd get a ton of use out of it in Canada, but what are your electric and gas rates? that would be the determining factor.
