Results 1 to 6 of 6
    Indiana
    vacuum sealed freezer
    My deep freeze creates a vacuum holding the lid shut...it seems to do it if you go back 10 min after opening it up.
    But if you wait a day u can open it up easily. Its a smaller model 3' X 3' X 3'. Was wondering if the small size was the reason...if it was a large one would the larger door and gasket be easier to break the seal on the gasket. Its always done this...just curious why. All other deep freezes i have opened i did not notice this.
    Kaufman county, Texas
    My home fridge has some sort of mechanism *I think* that does the same thing but it is only 20 seconds or so. Something was mentioned in the manual I mostly ignored.
    I guess if you have a perfect seal, it might just contract the warm air and create a vac.
    I draw all my schematics in crayon now. If they cannot always be correct, they can at least be colorful.
    Service calls submitted after 3PM will be posted the next business day.
    I give free estimates [Wild Ass Guesses] over the phone.
    I am not in business to make money from other people so that I can afford to work for you for free.
    If the fall is over, mmmm let's say, 6 feet or so,.. I do not 'bounce' very well.
    Aug 2010
    east columbus ohio area
    Confused
    I have seen this happen because of the magnetic strips in the door seals. If opened back up soon, the seals are still at room temp making them more pliable and creating a better seal making it harder to open. After long periods, the seals cool down, becoming harder on the inside and are easily broke free. These are just observations and/or guesses, much like a lot of things.
    Central WA
    Quote Originally Posted by Tool-Slinger View Post
    Yes, that... Usually there is a drain at the bottom of the freezer, or an air check valve in the back that will break the vacuum after several seconds. If it gets clogged or freezes over you have to wait for the gasket to leak enough to break the vacuum.
    Indiana
    thanks guys..
    Apr 2001
    Camel City, NC
    vacuum
    Commercial reach-in cabinets do the same thing. Some don't have vacuum breakers. When they are on casters you can pull them around by the door handle until the pressure equalizes (about 30 secs.). Have seen door handles broken due to this. You can depress the gasket (break the seal ) with your finger and open them easily.
    Be safe not fast. body parts don't grow back
