Thread: 1,500 Fed Credit question
08-11-2010, 12:47 AM #1
- Aug 2010
- Napa, Ca
- 9
Will a split system upflow Ruud 95% AFUE 2-stage w/variable speed configured with standard Rudd 14AJM 14 SEER AC unit make 16 SEER/13 EER for the 1500 Credit?
08-11-2010, 02:55 PM #2
need model numbers of outdoor, furnace and coil, to give you a yes or no.
The 14AJM gives me 1300+ matches that are eligible for the tax credit.Karst means cave. So, I search for caves.
08-11-2010, 02:58 PM #3
furnace does, it is installed price, to install the furnace you need furnace duct work, return, coil, thermostat...... you should cover the 1500 right there. What does your CONTRACTOR say?
Walter Matthau
08-11-2010, 07:03 PM #4
- Aug 2010
- Napa, Ca
- 9
08-11-2010, 07:12 PM #5
- Aug 2010
- Napa, Ca
- 9
Contractor says it does qualify. 14AJM is capable of 16.5 SEER with certain variable-speed furances. He showed me on a work sheet examples of four Ruud configurations using two 80% and two 95% furnace's. All according to contractor would be 16/13 systems. I just wanted to get a second/third opinion using this Forum.
Thanks for the reply's...
