My question is in two parts:
I think my house has a problem with negative air pressure. When the HVAC system is running (hot or cold), I get drafts from pretty much every single electrical outlet in the house (the windows are closed when this happens). The air is old, stale smelling and I have problems with allergies.
Here's question 1: I know that I'm losing some air in the crawlspace where the ducts are. Should I assume that if I could seal all those leaks I would acheive equilibrium in the living area? Or can you alert me to other factors I should consider?
Question 2 is related to loss of air in the crawlspace: I spent a half a day down there carefully taping every pinhole leak that could be found. The one I can't seal, however, is the biggest. It comes from the air conditioning coiling coil, which was poorly maintained by the previous owners and is rusted out at the bottom. I need to have that cooling unit replaced, but because of my allergies, I would like to have it relocated to the utility room where the furnace is located. My rationale is that it would then be far easier to clean/maintain the cooling unit while eliminating another opportunity for crawlspace air to enter the duct system. Is this the sort of thing a professional should be able to do for me? If so, what sort of precautions should I expect him to take? I don't want to introduce a critical error into the system.
I intend to call a professional, but I'd like to get as educated as I can first. Thanks.
1. make sure the duct is sealed and wrapped.
2. Depending on how tight your home is, you may need a
make up air kit.
3. If there is room for it in the utility closet, have it installed in there. If you have a counter flow furnace, the furnace will need to sit on top of the coil.
4. Have a hvac company come out for an estimate and request a manual j load calculation. This will tell you the proper size of furnace and a/c.
5. Make sure that you have adequit return air for the system.
6. Check into uv lights for your system. This will help your allergies.
“Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
Thank you, coolwhip.
I have one follow-up question:
I've looked a bit on-line about make-up air kits. We could be talking about something as simple as a vent/duct that leads from the exterior of the house into the return, correct? I'm asking because I want to be aware of economical options in case the professional I contact tries to sell me an unnecessarily expensive one.
Thats correct. Just a simple barometric damper.
Leaky ducts will cause the home to go positive or negative. The best method is to have the ducts pressure tested with a machine called a duct blaster. This will show how much and where the leaks are.
Best method is http://www.aeroseal.com seals and leak tests all in one operation.
Dash,
I've heard that the aeroseal can only seal small holes in the duct system.
Do you use an aeroseal machine? I would be interested to know it's limitations.
Originally posted by davidr
Dash,
Yes, we have been doing it for several years.
5/8ths of an inch wide by whatever size.
It's real advantage is it will seal very small leaks,that would likely go unnoticed with hand sealing.
gpl here (the original poster):
Regarding the use of a barometric damper, I have three questions:
1. Does a barometric damper just dump ice-cold winter air into the system? Or is there an economical way to warm the air a bit first?
2. Will a barometric damper on the return air line neutralize only the negative pressure that is caused by the furnace blower? Or will it also help correct negative pressure that is caused by combustion appliances and exhaust fans?
3. As I understand it, a barometric damper allows outside air to enter without dehumidifying it. In humid summer months does a barometric damper cause potential problems of excessive humidity in the system as a result?
Thanks. This is one of the most helpful Web forums I've ever come across.
1. Yes
2.Mainly the blower,but will help on the exhaust fans
3. Humidity is the same ,whether thru the damper,or sucked in the the cracks in the building,with a damper you can at least filter the air
Better to solve the main cause of negative pressure
Dash,
Thanks. By main cause, you're thinking it's probably the leaky ducts, right?
If so, I'm beginning to think it might be smartest for me to . . .
1. Remove my rusted out cooling coil, which is the biggest leak in the duct system. (There is an empty box under my furnace in the laundry room where a new one could go.)
2. Seal all leaks in the crawl and see if the negative pressure persists before considering installing any sort of make-up.
Does that make the best sense?
Originally posted by gpl
Dash,
Sounds like a good plan,adding a barometric may be good idea after the neg. pressure,is minimized.
To those whov've been such a good help to me in this forum, I just posted a new related question in the Residential HVAC forum. I posted it there because it seemed to me like it belonged there logically, but if any of you who've been tracking with my problem would be willing to take a look at it, I'd greatly appreciate it. I'm not reposting it here, because I understand that to be bad forum etiquette.
The subject is 'Plenum Box Necessary'
Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
