    Aug 2010
    Napa, Ca
    1,500 Fed Credit question
    Will a split system upflow Ruud 95% AFUE 2-stage w/variable speed configured with standard Rudd 14AJM 14 SEER AC unit make 16 SEER/13 EER for the 1500 Credit?
    Grottoes VA
    need model numbers of outdoor, furnace and coil, to give you a yes or no.
    The 14AJM gives me 1300+ matches that are eligible for the tax credit.
    Colorado flatland native
    furnace does, it is installed price, to install the furnace you need furnace duct work, return, coil, thermostat...... you should cover the 1500 right there. What does your CONTRACTOR say?
    Walter Matthau
    Aug 2010
    Napa, Ca
    Quote Originally Posted by karsthuntr View Post
    I do not have the furnace and coil model numbers. Furnace cost on contractors work sheet is 4K installed with all the usual code stuff.
    Aug 2010
    Napa, Ca
    Quote Originally Posted by spotts View Post
    Contractor says it does qualify. 14AJM is capable of 16.5 SEER with certain variable-speed furances. He showed me on a work sheet examples of four Ruud configurations using two 80% and two 95% furnace's. All according to contractor would be 16/13 systems. I just wanted to get a second/third opinion using this Forum.
    Thanks for the reply's...
