Results 1 to 9 of 9
08-07-2010, 06:30 PM #1
Tare weight of R-12 and R-22 30 lbs net cylidner?
Could someone post the tare weight or the gross weight(total) of a typical R-12 and R-22 30 lbs cylinder?
Thank you
08-07-2010, 06:37 PM #2
The weights aren't the same because the different manufacturers use different cylinders.
08-07-2010, 07:06 PM #3
- Jun 2003
- 3,633
usually around 6 LBS but it varies a little
08-08-2010, 05:23 AM #4
08-08-2010, 11:06 AM #5
Why does that matter? If you weigh it when you remove it and log it or either write it on the cylinder the tare weight is pointless.
08-08-2010, 02:33 PM #6
08-09-2010, 12:58 PM #7
- Jul 2008
- 23
Any of you guys make some big honking wind chimes with empty cylinders?
that seems like it would be a neat addition to the patio or man cave.
A little monofilament, some 1x2s and whamo, instant conversation piece.
Matt
08-25-2010, 05:00 PM #8
08-25-2010, 05:06 PM #9
