Results 1 to 9 of 9
Thread: Are two better than one?
08-07-2010, 03:11 PM #1
- Nov 2006
- 29
I was wondering, can two 1" 20 x 25 filters be stacked side-by-side for better efficiency? I know the big Air Bear's are the way to go, but they have gotten so expensive? Thanks for any help.
08-07-2010, 03:12 PM #2
Member
- Aug 2010
- 1
in life two is always bette than one hahaha
08-07-2010, 03:14 PM #3“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
08-07-2010, 05:06 PM #4
Side by side would give you 40X25, or 20X50.
If you mean 1 on top of the other. Just use 1. If you don't think the air near is worth the money for the better job it does.
08-07-2010, 10:59 PM #5
- Jul 2010
- SE Texas
- 122
Just change the filter more often
08-08-2010, 12:32 AM #6
- Aug 2010
- Quesnel, BC Canada
- 28
If you mean one in front of the other it's best not to. Two one inch filters will create more restriction than one two incher.
08-08-2010, 09:30 AM #7
- Jul 2010
- 53
Don't stack them one on top of the other for sure... that would create too much static drop and could really hurt the performance of your system... I would just go with the regular size filter....
If you use 2 filters side by side, there will be a dead space in the middle that will not allow airflow... calculate out the surface area of filter from one big filter to 2 smaller filters... Bet they are not the same dimension and thus not the same performance/pressure drop
08-09-2010, 02:41 AM #8
- Apr 2005
- Antioch, IL
- 35
I hate finding RTU's with two 1"inch pleated sandwich taped together. duh all too often
08-16-2010, 09:08 PM #9
