Results 1 to 9 of 9
    Aug 2010
    Florida Home - Furnace or Heat Pump
    I live in a south central florida and am about to replace by A/C unit. Currently I have a furnace installed and has served well.
    I am having estimates for a new system and half the contractors are saying go with Heat Pump and half are saying go with Heat Pump.
    I am confused.
    Any advise appreciated.
    Mar 2009
    Hollywood, Florida
    Quote Originally Posted by maxman View Post
    I am confused.
    So am I..
    May 2010
    SF Bay Area, CA
    Quote Originally Posted by fotofx View Post
    So am I..
    i guess we're all in agreement then?
    Jul 2010
    DFW -> Texas
    I am confused.
    Was or is your gas bill high? Why convert when you have the best in NG?
    Nov 2008
    Chapel Hill, NC
    I presume you meant to say "half said go with heat pump and half said go with furnace". Have them do an energy analysis to calculate the difference in bills with HP vs AC/furnace. If they are to lazy or ignorant to do that, keep looking.
    I don't know
    Post your electricity and gas rates.
    Provided that the outdoor temp doesn't drop below 32 (does it anywhere in florida?) and the electric rate is reasonable, you'll probably be best served by a heatpump.
    Today's units provide 3+ units of heat for every unit of electricity consumed above freezing - not bad.
    May 2010
    SF Bay Area, CA
    Quote Originally Posted by amd View Post
    I dont' know first hand, but I've seen the stories on the news of frost ruining part of the orange crop!
    Mar 2006
    The South
    max
    I see nothing wrong with a HP.
    you should analyze your fuel costs. see link below.
    even more, you will require at least a small heat strip for extra heating capacity when Central Florida has those freezing spells. Heat strips might mean modification/upgrade to your electric panel which means cost. only your dealer/electrical contractor can make a judgement there.
    IMO
    http://www.warmair.com/html/fuel_cost_comparisons.htm
    Or he can do a heat pump with a gas furnace as a backup.
