Results 1 to 13 of 14
Thread: Freon line making noise
08-04-2010, 10:34 PM #1
- Mar 2010
- Durham, NC
- 13
Is it normal for the copper line with freon in them to make noise? Almost like a water pipe with water running through it. It could be described as a scratching sound.
08-04-2010, 11:08 PM #2
Yes it is normal. The freon in the small line is (or should be) in a liquid state as it flows into the evaporator coil at the furnace.
08-04-2010, 11:11 PM #3
- Jul 2010
- SE Texas
- 122
Yep, completely normal.
08-05-2010, 02:13 AM #4
- Feb 2006
- Tn.
- 1,331
Yep it fine.
Knocking or rattling would be different.
09-04-2010, 10:04 AM #5
New Guest
- Sep 2010
- 1
If you can hear it in the wall from inside of the house you might have a kink in a copper line.
09-04-2010, 10:35 AM #6
09-04-2010, 10:44 AM #7
- Aug 2010
- 29
Are you sure this is normal. I have had several A/C systems installed in my house during the last 30 years. I have never heard anything from those pipes. I just walked to the Apt building acroos street from my house, there are about 20 A/C units on the ground there. heard nothing.
09-04-2010, 10:49 AM #8
- Nov 2008
- Long Island NY
- 124
thats alot of a/c units you've had over 30 years, try doing a little maintenance does it make the noise when the system is running or off?
09-04-2010, 10:53 AM #9
Am I 100% positive that you do not have any type of problem with your a/c: no. But I am not led to believe from what you describe that you do either. I would expect you to hear the noise, more at the indoor coil, where the metering device is. If it bothers you, pay a tech, to come and go over the system, then you will have the peace of mind you are looking for. No one can tell you for sure over the internet.
09-04-2010, 11:09 AM #10
- Aug 2010
- 29
Sorry, I should say my house(s), I moved 4 times during the last 30 years. But, What caused the noise in the pipe anyway? I heard people talked about this before. No one seems know exactly what is going on in there.
09-04-2010, 11:13 AM #11
Actually any tech, should know exactly what is going on inside there. Anyway as mentioned before, the refrigerant should be in liquid form, in the smaller of the 2 lines, when this liquid hits the metering device, which is essentially a restriction, and only allows a certain amount of the liquid refrigerant through at a time, noise often occurs, similar to turning on water at a low flow.
09-04-2010, 11:35 AM #12
- Aug 2010
- 29
I understand the theroy, but not every pipe make noise, some do, some don't. so there must be another factor in there did this ? You said 'often' occur, that means not always. that 'often' is a key. Interesting enough, one of my faucets(pipes) making noise when I turn it low as you mentioned, but not the others.
09-04-2010, 12:04 PM #13
Professional Member*
- Apr 2009
- Pan Handle, Fl
- 597
