Results 1 to 10 of 10
Thread: Flue pipe size
09-22-2004, 11:23 PM #1
- Mar 2001
- 475
I have noticed on some changeouts that the flue pipe is smaller than would be put in if it were new construction. For example, a 100,000btu furnace with a 40,000 water heater tied into a 5" flue. Is this an acceptable size. We only install 80 percent furnaces. Do you guys have a rule of thumb method of what size flue pipe to use on different furnaces?
09-22-2004, 11:29 PM #2
- Mar 2003
- Scottsburg, Indiana
- 354
all furnaces come with detailed, information on flu venting, its very important to be vented correctly. and with the correct pipe, the amount ran matters, pitch of the roof, etc. and why do you only put in 80%, cause you dont know how to do a 90, or you just dont know what your doing???????????no, there is no rule of thumb method.
09-22-2004, 11:34 PM #3
- Mar 2001
- 475
No need to get pissy. I don't do work for myself. I can ask my boss why we don't. There aren't a whole lot of 90 % in central Florida, and there definitely aren't a whole lot of people that would spend the extra money to upgrade everything for a 90 percent furnace. We mainly use heat pumps down here.Originally posted by customheating
[Edited by dave r on 09-22-2004 at 11:37 PM]
09-22-2004, 11:38 PM #4
That was kinda rude of old Custom maybe he has just had a bad day and came here to vent.
“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
09-23-2004, 12:02 AM #5
There is a vent table that you need to go by. Ask your supply house they should have something for you. It is important that you know the height of the chimney, (b-vent) the diameter and how many btu's the appliance is venting. The vent table will show you how many fan assisted and natural draft appliances you can connect to a certain run. If i'm not mistaken, 100,000 btu fan asssisted furnace with a 40,000 btu natural draft appliance can be vented with 5" b-vent minimum 15 feet high, as you go up in height, your btu allowance increases. But you should get yourself a vent table it makes life in "venting" much easier.
09-23-2004, 01:35 PM #6
- Jan 2004
- 49
The best reference for "B" vent sizing I've found is in the "National Fuel Gas Code". You may be able to purchase a copy from your utility, or perhaps even amazon. It also has charts for sizing gas supply piping, which comes in handy on larger jobs.
09-23-2004, 03:29 PM #7
- Mar 2003
- 354
sorry , didnt maen to get pissy
09-23-2004, 06:10 PM #8
I didn't think a was a bad answer myself, I mean there is no rule of thumb for venting as he mentioned. There are specific vent tables and codes you need to follow. Did I miss something?
09-23-2004, 08:53 PM #9I think it may have been this part of the comment that offended.Originally posted by customheating
dave r, This may be the most concise and informative information I have come across regarding venting practices short of the GAMA venting tables. Read it, print it and save it. It's invaluable info. http://www.duravent.com/docs/instruct/shbook.pdf
I printed it and placed it in it's own binder.
[Edited by HVAC Pro on 09-23-2004 at 08:55 PM]There is nothing more frightful than ignorance in action....Mark Twain
09-15-2005, 09:31 AM #10
- Sep 2005
- Cleveland
- 6
A house I bought has a 7in vent running up 21 ft alongside the house. I got a Carrier 75k furnace and a small water heater on a horizontal 4in vent going out to the 7in. I bought 25ft of 5in B vent at the store. The inspector called and said to go back to the store and check the sizing chart before I install the 5in straight up through the house. He thinks a 3in water heater and a 4in furnace are ok with the 5in but will check the chart.
