Results 1 to 9 of 9
    Jan 2010
    Bonney Lake, WA
    Steamer De-scaler
    I am looking for some input/opinion regarding a few steamer de-scaler applications. It seems that all of the manufacturers have their own products to descale their equipment. I work for a rather large school district with 31 kitchens; within those kitchens we have Market Forge, Stellar (MarFor,) Cleveland, etc. Most of our newer sites are using the Everpure SteamKleen system that that has a charcoal filter as well as a "scale stick" to slow the build-up of scale.
    I have used each of the manufacturers' recommended de-scaling systems/products from the pour-it-in-and-cook-it method, to the pump-it-from-a-bucket, to Everpure's powder-introduced-thru-the-water-feed. I use PH strips to verify water quality after de-scaling and it seems that they all do just fine. The Everpure system is, by far, the simplest and easiest of all the other methods and seems to be the safest.
    It appears that I may have just stumbled upon the answer I was looking for but welcome any opinions you may have regarding which methods are preferred in the field. Thank you...
    Jul 2009
    Connectitaxed
    Use an RO system for your water filtration.Pure water = no scale!
    "Time to nut up or shut up!" Tallahassee - Zombieland
    Apr 2004
    Charlotte, NC
    I like Lime-A-Way. Very simple, and many mfg recommend it. Also works weel in ice machines.
    "Fighting Ignorance since 1973 (It’s taking longer than we thought)." The Straight Dope.
    Jul 2010
    Fishersville Va
    I service 3 school districts, this year every steamer will have a Kleen steam attached.
    They just work, period, if maintained.
    For serious de scaling the everpure bags are the way to go.
    Albuquerque, NM
    Hard water sucks!
    Here in New Mexico we have very hard water. Every steamer that has a boiler is going to mean problems. The best descaler I have used is Cleveland Dissolve. As for water filters, the only thing I have found that actually works is RO. Be careful though you can still have electrolysis problems even with RO water. Ultimately the solution, I think, is boilerless steamers. Accutemp makes a very good boilerless unit and so does Cleveland.
    Mark
    NE Alabama
    Descaling methods depend on how often the units have been descaled. Whwn I tackle something witrh severe buildup I set up a system with a pump and inflow full strength descaler into the boiler/generator and outflow to a reservior (bucket/pan) with the pump in it, I run this until all scale is removed. Sometimes as long as two days while changing descale solution if it starts degrading enough. Once the boilers in question are clean I develope a plan through close observation to stop having a repeat of the type of buildup that caused such drastic action.
    Oct 2010
    The best descaler I have found to use with the Everpure system is from Enerco. Far better than the orange descaler Everpure suggests and very reasonable.
    I work a 10 school system and have the Everpure system,with scale sticks on all of em. Vulcans,Clevelands and 2 MarFos.I also descale twice a year with the ScaleKleen kilo bags.Good results.
    Our new county RO plant came on line last year.9/10(10th is on island)of my schools are on it,and you would not believe the difference! I haven't cleaned a solenoid in months.I'm definitely loving it.
    Feb 2011
    carbon block filters work, RO can become aggressive.
    Boilerless steamers still need to be cleaned daily. The only answer is dedicated maintenance.
