Results 1 to 7 of 7
Thread: Anemometer?
    Aug 2009
    Anemometer?
    What is the least expensive but accurate cfm measuring device (anemometer) to measure the cfm's from supply registers?
    Sep 2006
    Montana
    Are you a homeowner or pro?
    Aug 2009
    Homeowner... I am interested in measuring all of the air from the registers to determine how much air is actually being dispersed. Then I will be able to adjust dampers accordingly.
    Cal
    OPINION-
    Your method won't be very accurate, less accurate than instrument discrepancies/capabilities. Iffy numbers lead to iffy conclusions.
    Velocity readings are okay for coarse, proportional adjustments and may reveal face velocity issues.
    Gadgets like this will have accuracy tolerances/specs posted on line (+/- 2% for example).
    There are other threads like this, actually, everything (logical) seems like it's been asked about at one point or another.
    Sep 2006
    Montana
    It would probably be smarter to hire a local HVAC pro to come out a balance your system with a hood. They'll have much better equipment than you can purchase which will be much more accurate. Why would you want to spend money on something you're only going to use once or twice? Let the people who know what they're doing come out, you'll be much better off.
    The midwest.
    Quote Originally Posted by tomwk View Post
    A piece of Kleenex works well. And it's cheap. I used a piece to show a engineer (who knew it all) that he was short on return. I found 3 (out of 7)returns not connected on a 5 ton system.
    Massachusetts
    A ball shapped cat toy works great to illustrate the imbalance behind closed doors that have a small undercut. Get one with a bell in it and you can have audio as well as visual.
