Results 1 to 13 of 32
    Aug 2010
    Run capacitor Symptoms
    This weekend I had the displeasure of sleeping in a 85 degree house. Fortunately my home warranty company was able to locate a contractor that came out this morning to diagnose and repair the problem. They diagnosed the problem as a bad run capacity and dirty condenser coil. I was hoping that the community could tell me how these two problem actually relate to the problems that I was experiencing. Please understand I am not questioning the word of the technician I am only trying to understand how these two problems would contribute to the air not cooling properly. In fact, the air is now 21 degrees cooler as measured at a register.
    The primary problem that I experience is that the air conditioner would run but the air was only cool. After two hours of continuous running it would cool the house to 81 degrees.
    Aug 2010
    Lake Jackson, Tx.
    Bad run capacitor on the compressor or condenser fan motor?
    Depends on just how dirty the coil was as well.
    Jul 2010
    wouldn't a bad run capacitor on the compressor either make it overheat or not run at all? I am guessing it was a fan-related problem.
    Aug 2010
    Quote Originally Posted by FJRSTAR View Post
    I assume the compressor since they were working on the outside unit. I actually just got a call from my wife (who is at home) and she says it's not blowing cold anymore and the thermostat is still reading 81. I guess those where not the problems after all.
    Aug 2010
    Now they're saying that it's the compressor that is bad. 2-3 days to order the part and have it installed.
    Jun 2007
    Round Rock
    Sounds about right if the capacitor on the condenser was bad and the coil was dirty. Liken it to a car engine overheating for several days and you keep driving it. What will happen, you'll probably ruin the engine on your car. Same principle on the dirty coil. It causes the unit to run hotter than necessary. The same with the capacitor. If the fan side was bad, it will cause the unit to run hot, probably the compressor got hot. If the compressor side was bad, the compressor will also run hot. Its one of those things that happen. Had the tech suggested that you replace the compressor when he cleaned and replaced the capacitor. You would have been on here throwing mud on him for trying to rip you off.
    I like DIY'ers. They pay better to fix.
    Delaware
    Make sure they clean the coil. If it was clean from the get go it would still be running. The dirty condensing coil started all the problems. I would get a second opinion.
    Always here
    Aug 2010
    Thank you for all the tips. The repairs are covered under our home insurance. It has been mentioned a couple of times that the dirty coils likely caused the problems. What maintenance and frequency should I have a professional do so that the chances of this happening again.
    Warren, MI
    Quote Originally Posted by bmathews View Post
    If a bad capacitor on both the compressor and fan caused the compressor to run hot, why didn't the compressor's thermal/current overload protect it?
    Bill
    Delaware
    Quote Originally Posted by jrack04 View Post
    Make sure your dryer vent is not located to close to the outdoor unit. Try to divert it a bit if it is. Once the coil is clean...you could hose it off yourself once a month. Ask the service company to show you. It's easy.
    Always here
    Yakima, WA
    Bad run capacitor can mean failed or just weak. Weak means the motor will likely still start and run, just work a little harder and the capacitor may be getting ready to fail. It's a good idea to change it before it fails altogether.
    A dirty condenser coil means the unit can't reject heat. Temperature is directly related to the pressure of the refrigerant, and the compressor has to work much harder to maintain the higher pressure. The coils don't get dirty right away, it builds up over time, so when it gets to the point where it can't function at all you have been working your system very hard for a long time, which will put excessive wear on the compressor.
    The condenser should be washed out at least once a year. When I do a maintenance I also pull the top of the unit and back wash as well. Also you can pull the leaves, action figures, and other crap out that makes its way into the unit.
    Jul 2010
    Andalucia
    You are lucky the warranty company is covering it because with the dirty condenser most would have said it was lack of maintenance, which is your responsibility. Good luck
    Benghazi was a 4 year investigation, there were zero indictments. The Clinton emails was a 2 year investigation, there were zero indictments. The Mueller investigation has been 12 months, there have been 23 indictments.
    When 11 American prisoners in North Korea were released during the Obama administration, the President didn’t make it into a spectacle about himself.
    Trump was right Roseanne is about you.
    Aug 2010
    Marshalltown, IA (The new rainforest)
    @pageyjim, most home warranty companies exclude regular maintenance in a situation like that because the homeowner does not readily know about a dirty coil causing these kind of issues.
