    NJ
    Have a old small dehumidifier which leaks about 2 oz. per year
    and cannot find leak. Need a recomndation of what new type
    refrigerant I can use (in charge a cans). I am a retired hyvac mech and out of the r-12 it takes. Also, what pressures
    would this new refrigerant have. (hi and lo side). I do not
    wish to have change to the oil. Just evacuate the system and go.
    Jan 2003
    Olathe Kansas
    Be better off if you purchaced a new one. I think you can still get 134A in small cans but you'll need to change oil.
    Sep 2001
    East Stroudsburg, PA
    Yeah, you can get a new one pretty reasonably.
    134 is the only one that I know of that is available in the 10 oz. cans anymore.
    You must have some old buddies still in the business that could hook you up with a shot of MP39 or 409A, don't you? Or did you burn all your bridges like I'm in the process of doing?
    Where are you in NJ, BTW?
    NJ
    condeseddave
    I live in Middletown NJ. Just outside of Red Bank.. What
    pressures should I expect from 409 a ? Use same oil I hope.?
    Bad to use 134a without changing to the new type oil??????
    Sep 2001
    409 will run a higher discharge temp than 12.
    I wouldn't hesitate to try 134a without an oil change on something that small, but that would be entirely up to you. The manufacturers require a conversion to POE. I've done it in the past, on larger equipment than that, but, again, I can't guarantee it would work...
