Results 1 to 13 of 23
Thread: Wrench Sizes
    Maryland's Eastern Shore
    I know that the a good service tech would have 3/8", 7/16", 1/2", and 9/16" wrenches in his bag... Would anybody add to that... Does anybody use a regular combination wrench to remove carrier service valve (king valves) stem covers?... Does anybody use a wrench to remove the caps on pump down valves?.... I use nutdrivers for 11/32", 3/8", and 7/16" for blower wheel mounts, and was considering using a 1/2" for compressor mounts, does anybody else do that?... OR do people have a small and a large adjustable wrench do it all? Or the least best option, a pair of channellocks?
    Nov 2000
    Memphis TN USA
    I use a 1/4" drive socket set. Works most of the time.
    If the superheat ain't right it ain't charged right.
    Jul 2001
    What is a pumpdown valve?
    Wrenches for most work, and 4 sizes of adjustable wrenches.
    Plus sockets for compressor mounts.
    You can never have too many tools!
    You can have a tool bag thats too heavy.
    Florida
    I like having flare-nut wrenches on me....great for preventing busted knuckles.
    Stoneham, MA
    I agree with Beenthere. I have a standard 7pc nut driver set, use 1/4, 5/16, and 3/8 the most. Adjustable wrench to take covers off King valves, and I also carry a Craftsmen set of wrenches. Open on one end and ratcheting boxed on other end. That ratcheting box end comes in handy a lot to get to screw heads that don't even have enough clearance for a socket in fromt of it. I don't use them often but when I do I'm REALLY glad I got them.
    Always give your best effort, be honest, and let the chips fall where they may.
    Nov 2000
    Memphis TN USA
    Mrs. Kim does not beleive that. She thinks I have too many tools.
    S.W. PA
    well my wife also thinks i'm in bussiness to collect tools, i keep 3/8, 7/16, 1/2, and 9/16 plus somewhere at the bottom of the bag are 1/4 and 5/16 other than that theres a whole set in the truck every size i could need.
    Jul 2003
    sacratomato
    My wife gave up on asking what tool I was buying now, hence the user name (Binford)
    I also carry a pair of needle nose vise grip pliers.
    Dec 2003
    Nevada
    Offset boxed end 3/8"x7/16" and 1/2"x9/16" are very valuable.
    Quote
    “Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
    "We can't solve problems by using the same kind of thinking we used when we created them."
    Albert Einstein
    Post Dewalt ...
    Most recent addition to my coolection is a cordless DeWalt Impact Wrench. Had to rotate the bell housing on a compressor change out and was in a tight spot made quick work of things...
    AllTemp Heating & Cooling
    Dec 2003
    those gear wrenches are handy, esecailly the 5/16" and the 1/4" for those tight spots.
    there but for the grace of god, go all of us
    May 2003
    Pipe Wrench
    I like to keep a 4' Rigid steel pipe wrench in my pocket just in case.
